Question about Dryers
Gas Dryer in Auto sensing mode doesn't work, only in timed mode
I got an answer from Jhony Rendon on April 6, 2015 but his comments assumed it was an electric dryer.
    Top Expert:
  • Dryers Master
  • 48,487 Answers
Well since you did not say in the question what it was we can only guess .so Jhony guessed wrong so what
Posted on Apr 07, 2015
Dryer will not stop when clothes are dry in auto-sense mode
Try "timed" cycles. If it shuts off on timed it's not the timer. It's more likely it's not cycling on the thermostat due to an airflow problem like the vent. To rule that out (or in) run ONE load through it with the vent disconnected. If it shuts off you'll know where to look
May 03, 2014 | Admiral AED4475TQ
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Hi I have a GE Profile DPGT750GC gas dryer and it doesn't heat. I've had this model for a few years and it worked fine until about last year. The drying wasn't good at times but didn't...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 11, 2011 | Dryers
The gas dryer works on timed dry but not any autosense cycles. The sensors were cleaned and 2 seperate service people checked it.
your post did not say if you have removed the vent tube and ran the dryer in any of the auto-sense cycles, I would do this first. If it runs normally with the vent disconnected then the vent is restricted. if you have already tried this then the reason it may not be working is that the wires(either blue or green) behind the sensor bars is/are disconnected/broken. There is a diagnostic mode you can enter to test the control's ability to sense the bar contact that is illustrated in the tech sheet which is located within the control panel, when you are in the diagnostic mode touch the two wires of the sensor together and if the light illuminates, it means the wiring to the sensor block and logic of the control is good. If the light doesn't illuminate, then either the control is bad or one of the blue wires is broken or not connected at the control. Hope this helped Tim
Mar 11, 2011 | Bosch Nexxt WTMC3521UC Gas Dryer
Amana lga30aw. dryer starts in auto mode, pilot on, gas on, goes off after awhile and never comes back on. timer does not move in auto but does move on the timed mode (still does not dry in the timed...
You may need to replace the timer, but watch the video below and it will walk you thru the troubleshooting process. The timer not moving in the "auto sense" mode maybe due to a bad thermostat. Here is a link to the timer in case you need it.
Jan 05, 2011 | Amana ALG331RAW Gas Dryer
My whirlpool dryer heat does not stay on. when i first start it , its hot then the heat turns off. it continues going with no heat
With the limited information you gave I will assume this is a gas dryer that the flame starts for a minute or so and then shuts off. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Oct 09, 2009 | Whirlpool Dryers
When I start the dryer in either auto or timer mode the burner starts and the heat comes on. It will run for awhile with heat and then the burner will shut off. The dryer continues to spin but no heat is...
Oct 06, 2009 | Whirlpool LGR3624JQ Gas Dryer
Auto sensing does not work. dryer continues to run
Inside the drum under the filter is 2 long skinny strips of metal mounted in plastic. Clean then sensors up with alcohol. They get goop on them from soap and fab softener. I have a manual here that feature auto sensing circuits and photos CLICK HERE FOR THE MANUAL
Sep 07, 2009 | Estate TGDS840JQ Gas Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
