Question about Saws
What size carbon brushes does this Mastercraft angle grinder use
2 Suggested Answers
brewerstool
  • 141 Answers
SOURCE: Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Posted on Sep 15, 2009
Where would I find carbon brushes for my agojama 9ins grinder
angle grinder
if nothing for the on ebay for agojama
Amazon
or source brushes from a local electric motor repair business
certain electricians
you might be able to solder in (retro fit )
another makes brushes if the same shape and size for that agojama
Jul 08, 2016 | Saws
How can i replacethe carbon brushes on my angle grinder as they are totally and completely worn off
Buy the new brushes from the manufacturer. You already have the old ones out - put the new ones in the same way you took the old ones out.
Jul 27, 2014 | Makita 9005B 5" Electric Angle Grinder
Brushes angle grinder
First try a good hardware store. Take out a brush and take it with you to match it up.
Apr 28, 2014 | Saws
Replacement carbon brushes Ryobi AG402 angle grinder
You can purchase replacement carbon brushes on amazon Amazon com Ryobi carbon brushes. I hope this was helpful. cheers
Jul 12, 2013 | Saws
Brushes for drillmaster grinder
looking for carbon brushes for a drill master model#69079
Jun 09, 2012 | Master Heaters Drill Master 412" Angle...
How do i change carbons
There should be either one or two access screws(usually black in color,plastic looking) on the body of the grinder. remove screw cap,holddown spring,and remainder of 'brush'/carbon. Reverse steps for installation.
Aug 09, 2010 | Hitachi G10SR3 4" Angle Grinder 6 Amp
Angle grinder eats carbon brushes
Yes, the rock dust is what's destroying your brushes and armatures. It gets sucked into the rear vent slots and gets to those parts and eats them away quickly. I don't know of any vacuum systems make by Makita but there are some companies that make them for their systems. Blastrac is one that comes to mind but they can be real expensive systems. I don't know of any grinders with sealed brush/armature systems, they have too much heat to disipate. To make your Makita grinders last longer make sure you are cutting with the side of the blade that directs the dust away from the case and try to have a strong airflow blowing the dust away from the grinder to minimize the dust taken in at the back of the grinder.
Jul 15, 2010 | Makita 9005B 5" Electric Angle Grinder
I had been using this grinder for about 2 weeks with no problems. A few days ago while using it it just popped and hasn't worked since.
These are great grinders. I have two of them. One version (more expensive one) has soft start and good overload system. Other version is basic grinder. if it (popped) most likely a short in the motor. Is it possible you got an unusual amount of grinding dust into the grinder? This grinder has a safety feature on the brushes, that keeps from burning up the armature when the brushes wear out. I doubt you've worn out a set of brushes in 2 weeks, unless you've been using it non stop. At least one of the brushes has a small plastic insulating pin inside the carbon. When the brush wears down enough to expose the plastic pin, the spring loaded pops out, lifting the brush from the armature , which opens the circuit. You could remove the brush holders and inspect the brushes. If it is 2 weeks old it is under warranty, and you should return it where you bought it.
Jul 14, 2010 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Carbon brush sizes
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
Mastercraft 14-in. Chop Saw w/ Laser fuse problem
The fuse is more than likely, fine.
Instead, check the carbon brushes.
Once you have dis-assembled the unit, you will see the way the springs hold them in.
If you can't find the brushes, chances are, they've desintagrated into micron thick diamonds.
(Unfortunately, they're worthless diamonds lol)
Hope that helps the problem.
Jun 28, 2009 | Saws
Saws Logo
342 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
