Question about Motorola Moto E
White light on and the will not turn on - Motorola Moto E
  •  johnny rebel
    johnny rebel Apr 07, 2015
    Hi James New, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Motorola Mobility
    Motorola Mobility Apr 08, 2015
    James. What Model phone? Moto G? Moto E?
  • Official Brand Answer
  • 3,100 Answers
James
Our.phones have a light indicator when fully depleted that will turn on during charging until the phone can power up.
Mark
Motorola Support
Posted on Apr 08, 2015
My washing machine just turns white light on display but nothing to display and white background light also comes when i turn it 2 times on n off
Good Morning Friend,
I understand you are having trouble with the display on your Electrolux washer, model# EWX14450W. In researching your model number, I have determined that it was manufactured in the UK. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction for having your display repaired. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux Washing Machines
Tip
Wiring Different Trailer Types - Highlander
Hello all,
For those of you that need to wire up a trailer or have to occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Blue = Electric2_bing.gif Brakes - 2
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery2_bing.gif, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
A test light and a 12VDC power source can be handy for trouble shooting.
Best regards
Mike
on May 16, 2010 | Toyota Highlander Cars & Trucks
Tip
Trailer Wiring Problems?
Hello all,
For those of you that need to wire up a trailer or have to occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on May 16, 2010 | Toyota 4Runner Cars & Trucks
I replace my brake switch & my light don't work? when i stop
IF THE FUSES INSIDE THE CAR & UNDER THE HOOD HAVE ALL BEEN CHECKED WITH A GOOD FUSE TESTER, & THE BRAKE LIGHT SWITCH REPLACED, THE TURN SIGNAL SWITCH IS NEXT. THE BRAKE LIGHTS GO THROUGH THE TURN SIGNAL SWITCH SO THEY CAN BE USED AS TURN OR BRAKE LIGHTS. I'M ASSUMING THE BULBS ARE OK. REMOVE THE PLASTIC FROM AROUND THE TURN SIG. SWITCH. STAY AWAY FROM ANY WIRES THAT ARE IN THE YELLOW SLEEVE. THEY ARE AIR BAG WIRES. WITH BRAKE PEDAL DEPRESSED, THERE SHOULD BE POWER IN THE WHITE WIRE. IF THERE IS NO POWER IN THE WHITE WIRE, YOU MAY HAVE TO PUT A BYPASS WIRE FROM THE WHITE WIRE COMING OUT OF THE BRAKE LIGHT SWITCH TO THE WHITE WIRE GOING INTO THE TURN SIGNAL SWITCH. IF THAT DOESN'T MAKE THE BRAKE LIGHTS WORK, THE TURN SIGNAL SWITCH MUST BE BAD.
Jan 26, 2011 | 1999 Chevrolet Malibu
What causes the brake lights not come on,but allow 3rd mount light to come on? i've checked the bulbs,sockets,fuses. now i'm stumped.
THOSE LIGHTS ARE ON 2 DIFFERENT CIRCUITS. ONE WHITE WIRE COMING OUT OF THE BRAKE LIGHT SWITCH GOES TO THE CENTER BRAKE LIGHT. THE OTHER WHITE WIRE GOES FROM THE BRAKE LIGHT SWITCH TO & THROUGH THE TURN SIGNAL SWITCH SO THE LIGHTS CAN BE USED AS BRAKE LIGHTS OR TURN LIGHTS. THE BRAKE LIGHT SWITCH IS GOOD BECAUSE THE CENTER BRAKE LIGHT IS WORKING. IT IS A BAD WIRE { WHITE } FROM THE BRAKE LIGHT SWITCH TO THE TURN SIGNAL SWITCH OR A BAD TURN SIGNAL SWITCH.
Jan 17, 2011 | Buick Riviera Cars & Trucks
Tip
Trailer Wiring
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
Red or Black (not both) = Battery, aux power - A
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Jan 09, 2010 | Cadillac Escalade Cars & Trucks
Tip
Trailer Wiring 101
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Jan 09, 2010 | Dodge Ram 1500 Cars & Trucks
I have power in 14/2 and 14/2 out to light. how do I wire the switch. I tried putting whites together and blacks to switch but it doesn't work.
Your breaker is not tripped.
Your light bulb is working.
You have a working on-off switch that has two brass screws and a green ground screw.
That is a single pole switch. Black wires go on either brass-colored screw, and whites are twisted together.
If switch has 3 screws and ground screw, connect black wires to dark-screw and one of the brass screws.
First you should test your wires.
You have 2 cables.
Both cables have black, white, and bare copper ground wires.
One cable goes to light.
Other cable comes from breaker box.
Cable from breaker box has black-hot wire and white-neutral wire.
Turn on power and test black wire to white, and then test black wire to ground.
Tester should light up with both tests.
If tester does not light up, then breaker is suspect, or there is a short in nearby box.
Track back the short towards breaker, going one box at a time, each time testing black to white and black to ground.
Next, inside the switch box, remove the switch and connect both cables without the switch.
Black to black
White to white
Turn on power, does light turn on.
If light turns on, your switch is suspect. Connect new switch. One black wire to each brass screw, and then tie white wires togethr.
If light does not turn on, your light is suspect. Open light fixture and test black to white and black to ground again.
If light tests with power, then check your bulb
If light has no power, then wire between switch box and light is suspect.
Dec 06, 2010 | Electrical Supplies
Tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 23, 2009 | 1998 Ford Explorer
Tip
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 19, 2009 | 1987 Jeep Wrangler
Motorola Moto E Logo
35 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Trisha
Trisha
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
