S07 error, what does it mean? - Washing Machines
  • tom cassidy
    tom cassidy Apr 13, 2015
    Hi Penny Wray, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
I have a Simplicity S07 DecoMate and I cannot get the bobbin thread to pick up.
If the machines are very similar, then they most likely thread the same. Usually, the only difference is that sometimes one will have a few extra fancy stitches or extra feature.
Be sure to install a brand new needle. (Be sure the needle is inserted correctly--the flat side faces a particular direction.) Check that the bobbin is installed and threaded correctly in the bobbin case (is it turning the correct direction). If this doesn't resolve the issue, the machine has most likely been knocked out of time--most often by hitting a pin or a particularly thick seam. You can search online for sewing machine timing or take it for service.
Jan 11, 2017 | Simplicity Sewing Machines
Need a new foot pedal
you put your question under Simplicity DecoMate SO7,,so that is
the model I looked up, http://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
$34.99 plus shipping
if the machine is different go to sewingpartsonline.com
Jul 25, 2012 | Simplicity DecoMate S07 Mechanical Sewing...
Need guide how to thread
sewusa.com has some diagrams for threading
youtube & ehow have video's
these sites for a manual
sew4less.com
Apr 14, 2012 | Simplicity DecoMate S07 Mechanical Sewing...
Looking for an owners manuel
try these sites
sew4less.com
sewusa.com
premiersewing.com
sewingmanuals.com
ebay
May 14, 2011 | Simplicity DecoMate S07 Mechanical Sewing...
Treading maching
the question is under
Simplicity DecoMate S07 Mechanical Sewing Machine--but is the machine a treadle sewing machine?
Could you tell me what plug in ports i need for X540 or 530- on my desktop
You need three ports in order to use all the speakers 5.1 sound. They are all headphone jacks but they are front speakers, rear speakers, and sub/center
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=36-121-006-S04&SCList=36-121-006-S01%2c36-121-006-S02%2c36-121-006-S03%2c36-121-006-S04%2c36-121-006-S05%2c36-121-006-S06%2c36-121-006-S07%2c36-121-006-S08%2c36-121-006-S09%2c36-121-006-S10%2c36-121-006-S11&S7ImageFlag=2&Item=N82E16836121006&Depa=0&WaterMark=1&Description=Logitech%20X-540%2070%20watts%205.1%20Speakers
8th pic
Apr 06, 2010 | Logitech X-530 Computer Speakers
This unit just won't work at night
I had a similar issue with a product but not the same brand. It ended up being one of the many boards on this system even after the manufacturer said that the board that ended up being bad couldn't make the system behave in the way it was. After I replaced the bad board, it worked like a champ. I would recommend replacing the indoor pc board anyway. If that doesn't work, then there has to be something wrong with the wiring in the unit. If your charge is perfect then it wouldn't work even in the day time not just night especially if it were the expansion valve. I'm thinking that the units aren't communicating properly. Hope this helps.
Mar 18, 2009 | Sanyo 24KS72 Split System Air Conditioner
Washing Machines Logo
Top Washing Machines Experts
