Question about Fitbit Zip Pedometer Charcoal
I am having to replace battery abt every six weeks. I did do a update yesterday.
Watch stopped working
The battery is the first thing. You have no way of knowing how long the battery was in that watch before you bought it. Batteries are installed at the manufacturer and the battery might have been old before it was installed, then the watch might have sat in a warehouse for years before you bought it.
Mar 02, 2014 | Raymond Weil Watches
96 accord ex 4cyl wont start battery new
bang, on the starter with a hamer all around the casing,the brushes wear out and no longer make contact with the comutator will useually make them move as they are sping loaded, this is a temp fix and only good 4 a cple of weeks! u can change the starter 4 abt $100 bucks or pay $150+ 2 have it done! and ur gonna get a referb bad piece with a $50 buck core charge!!!rip off. what i do is buy the brushes from th auto pts store and replace them ur self abt 6 bucks abt 1 hrs work!
let me know if it worked 4 u!
Jan 17, 2013 | Honda Heating & Cooling
Battery good; All panel instruments appear to be operational; no fault displayed yet get no ignition. Same thing happened yesterday. after driving back from work, stopped at store. Was inside for abt 45...
Sorry I got to your question too late. Sometimes a weak solenoid doesn't get enough voltage. Some over come this with a relay bypass, a direct line from the battery to a relay controlled by the ignition to the solenoid. I'm glad you found the problem.
Oct 04, 2011 | 2001 Buick LeSabre
My nokia software updater hang during a software upgrade. After that, it only vibrate when I turn it on. But screen is always black. What can I do?
dont worry abt that.
-switch off ur phone and take out battery for abt 15 seconds. -reinsert the battery and switch on the phone. -connect the phone with pc -start the nokia software updater and let it detect the phone. -reinstall the recommended update.
i hope this helps.
Mar 06, 2011 | Nokia E71 Smartphone
Purchased an 800 twin electric atv abt 1 month ago. love it. stopped working last week. no idea what is wrong, or how to fix it
try charging the batteries if that doesn't work than replace the batteries. You can find replacement at walmart
Aug 18, 2010 | Toys
Phone battery died and wont on or charge
Please got the dealer from where you purchased the phone and ask him to replace the battery as you have used it only for a week. It should be under warranty period
Apr 17, 2010 | Nokia 5130 Cellular Phone
I have a 2001 camry LE six cylinder, and it will not start...has
you need to check your wire connections to the battery tighten them and if that doesnt work. then have your battery tested ,if the battery is good .then pull the starter and have it checked
Nov 02, 2009 | Toyota Camry Cars & Trucks
MP4 Player Dead
just let the battery run out and wut ever u was trying to do delete it off
Apr 23, 2008 | Audio Players & Recorders
Fitbit Zip Pedometer Charcoal Logo
115 people viewed this question
Top Fitbit Exercise & Fitness Experts
ray gallant
Ravi
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
