Question about HP PhotoSmart Office Equipment & Supplies
How to scan to my PC - PhotoSmart HP Office Equipment & Supplies
    Sergeant:
  • 330 Answers
If your printer is already connected and the PC recognized, go to your PC "CONTROL", select "DEVICES AND PRINTERS" on the drop down menu. All your devices will be laid out in front of you. Click on your Printer logo. After you put your work to be scanned face down under top cover, follow the instructions to scan. You even have the option to preview it before you press "SCAN".
Hope this is helpful.
Posted on Apr 07, 2015
How to scan through pc in xerox 3535 ?
acually
there is a scan procedure manually in 3535
on machine go to scan option
set scan option like paper, photo mode etc
and just scan remember mail box name
then form pc browes ur machine ip
if ur having java aplet on ur pc
it shows web tools
go to
webscan option
write ur mail box name
refresh
it shows ur scan document
then set ur file format JPEG or pdf then click to save as
it will be download to ur pc
Aug 05, 2010 | Xerox DocuColor 3535 Copier
Slow speed of computer , should be high
scan your PC for viruses.
Download Malwarebytes. Install it. Update & run a scan.
LINK
fix all the entries found.
Also download & install CCleaner & scan your PC with it
LINK
This should improve your PC's performance.
Jun 28, 2010 | Dell Dimension 2400 PC Desktop
I AM ATTEMPTING TO USE THE SCANNER FUNCTION ON A CANON IR2230
Firstly, the machine must be connected to a pc or network. Secondly, you must scan the document to a pc so, after you have switched on, as you have, the scanner so that it says 'online' you will need to go to the pc and 'PULL' the document to the pc from the scanner. However, to do this you will need to have installed NETWORK SCAN GEAR on your PC inorder to SCAN. When you install the software, you will need to DISCOVER the scanner before it will be ready for use. So, a recap:
1. You NEED a program called NETWORK SCAN GEAR on your PC
2 Your ir2230 must be connected to a PC or network
3 You need to DISCOVER your ir2230 from your PC
4 You then need to INSERT picture FROM SCANNER and select your ir2230 from within a program such as WORD using NETWORK SCAN GEAR
Good luck
Jan 01, 2010 | Canon IMAGERUNNER 2230 Copier
I press scan but nothing happens I scan on cannon Mp 160 and I cant scan with my pc
Make sure the scanner is connected to your laptop/PC before you press 'scan' and is turned on.
Pressing the scan option will start Canan's software MP Navigator for scanning. You can also start MP Navigator on your PC and then start scanning directly from your program or from the printer button.
Dec 31, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Able to copy and print, scan & print, but not able to scan to pc
is your printer setup to scan to pc.need to setup email address etc.
Jun 30, 2009 | Office Equipment & Supplies
HOW TO SCAN FROM SCAN TO BUTTON IN THE NETWORK FROM HP 2727MFP
You need to install the HP Scan software on each and every PC the MFP should scan to. In this software, you can create targets for the "Scan To" button. But: This is only useful when scanning with the ADF, because when scanning from the flatbed, you'd need for every page to hit the "Scan To"-button, press "Scan", wait for about a minute or two until the MFP has found the appropriate PC, and wait for the scan. So network scanning is unfortunately very limited with this machine.
Mar 12, 2009 | HP Laserjet M2727nf Multifunction Printer
Scan to pc
On my version of the hp software I can quite easily do this.
You will need working email software on your pc, so to scan the image, ensure that the pc is connected to the scanner and the pc is switched on - with all the HP scanning software installed.
Press the scan button on top of the scanner, with the document inside the scanner faced down.
When the HP Software pops up on the PC - the scanned image should appear. You can then click the email as attachment button in the HP software.
There are many ways to do this operation. So if you get stuck then let me know I we can go into more detail.
Please don't forget to rate.
Jul 04, 2008 | HP PhotoSmart C4180 All-in-One Color...
Scanning from printer
This is a loaded question. First, make sure the folder youre scanning to has full permission and that it is shared. If its shared, the most common issue is that the password on the server has been changed. When a ricoh scans to a server or pc it asks for the password and login name of the pc or server. If it has changed from the time scanning was set up and can longer authenticate to the pc/server so your scans will not go thru
Mar 11, 2008 | Office Equipment & Supplies
Seeker5211
Seeker5211
