I have changed Batteries in the hand-held remote but no response on system or light for our pool.
System and light respond from main panel board, but not from remote. Product is 8 tears old
    Master:
  • 301 Answers
Following these steps
1. double check the batties
2. to go remote and double check to make sure that it getting electric
3. double check the circuit breaker, sometime you have to throw the switch off then on again if it tripped.
4. Call a electric you might have a bad circuit breaker or a short.
Posted on Apr 07, 2015
My Pentair Easy Touch inside remote reads 'No Comm' even though batteries are fine. I get the same message even close up to the transmitter antenna. My pool service looked at it and noticed
Your power center outside has to be "trained" again so it and the remote recognize each other. I don't have the charts in front of me but check your manual or one online. It's fairly simple to do.
If that still doesn't work, the problem may be with either the remote or the power center. Good luck with it.
Jan 16, 2013 | Pentair Easy Touch Indoor Control Panel...
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
You can here a click but remote does not operate fan or light
If you haven't changed all the batteries in the remote controlled system, now is the time to do so. Keep in mind, there is a battery(s) in the hand held remote and in the receiver inside the cowling of the fan.
When changing batteries, ALL batteries should be changed at the same time.
Hope this helped you. Please let me know. Thanks.
Jun 23, 2011 | Heating & Cooling
Control panel in house is all lit red doesnt respond lights wont go off all systems are froze bad storm transformer blew on pole
Time for a repairman to check your system. The storm may have burnt out your main boarde if you don't have a surge supressor onn the system.
Jun 25, 2010 | Jandy Aqualink Rs4 One Touch Control...
My remote held hand unit is stuck saying Handheld 1.38 waiting
make sure 4 pin red plug is plugged in at PCB board or check to see if antenna wires cut
May 18, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Remote car starter no longer works. i replaced the battery in the hand held, yet still no response.
under the dash remove the main fuse or fuses from the main module for 2 min then replace and reprogram your remote
Mar 18, 2010 | Remote Start System
I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
Nov 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
The TV does not respond to the channel changer. changed to a new changer and batteries but did not correct.
Do you mean changer is a remote control? Try to use manual buttons to see whether the TV work. If it does not response either the problem comes from the input/output controler or main board.
Aug 11, 2009 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
