I've had a oase clear water filter for three years now with no problems. I was cleaning it at the weekend I notice water leaking out off the function switch I would appreciate any advice thanks Dave
    Master:
  • 301 Answers
It should you did seat down correctly, take out the filter and put back in. You might want to inspect the rubber around the filter for wear.
Posted on Apr 07, 2015
  • 641 Answers
SOURCE: Intermitant water leak.
Put a newspaper under the machine, it will help you to find out from where does the water leaks. Good luck!
Posted on Sep 06, 2007
  • 115 Answers
SOURCE: leaking water from the bottom
take the back cover of ,first check if all the water hoses are tighten,if all tighen then its leaken around the motor area might need a new motor or gasket ,check it when its running so u knw where exactly the leak is,for more info let me know,if my info was of any help to you please leave a comment,thank you.
Posted on Sep 03, 2009
richroth
  • 9472 Answers
SOURCE: Whirlpool Model GHW9100LW1 leaks water
You need to replace the boot. Here is a link to the part.
Posted on Jan 02, 2011
Testimonial: "Good solution but I found a better solution with a repair kit."
  • 11 Answers
SOURCE: I have a LG Fuzzy logic for a year and a half now,
certain materials give off fluff and some others seem to attract it. you can try putting in similar materials together and avoid mixing turkish bath towels, blankets and jackets and such clothes having fluffy lining with normal clothes. Also try selecting higher water level (overriding the automatic selection) manually. Once when i had fluff on clothes, it turned out to be tissue paper from my child's jeans pockets. After cleaning the filter bag, run the machine empty at maximum water level every week. Hope one of these will help solve your problem.
Posted on Jan 17, 2011
  • 118 Answers
SOURCE: Hi there I'm a first time
Hugh It sounds like the rubber door seal is leaking The seal will have tio be replaced if the \re is a hole in it. Quite simple really.
Posted on Apr 25, 2011
Testimonial: "thanks for the quick response I thought that might be the problem but is there other places that leaks could occur at the front?"
Is a kaz water tank leak under warranty?
I doubt if there is any warranty on this now. It has been over three years ago.
May 18, 2017 | Honeywell Humidifiers
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
Water won't flow thru to filter or pot. Don't know the exact model but it is a 12 cup self cleaning.
Self-cleaning is wishful thinking. Every three months or so, run a pint of vinegar through it, as if making coffee (no coffee!) then flush with two tanks of water.
Mar 27, 2013 | Mr. Coffee Coffee Makers & Espresso...
I have 7 year old Hayward ProSeries, S-244S, H/R Sand filter. I've notice that when I vacuum the pool, dirty water returns to the pool. I've backwashed and the spider gasket is fine. No sa
sand filters only have limited filtration. If the dirt is very fine such as dead algae, it will go right through the filter. Use a clarifier to help give the filter finer filtration. Do not vacuum until you can see what you are doing, then vacuum on 'waste'
Sep 19, 2012 | Hayward SAND FILTER, PRO SERIES
My Haier dehumidifier is harly removing any moisture from the air. It appears to run normally and I have cleaned the filter regularly. I've owned it about a year and it is model HD456E. It worked very...
If the evaporator coils behind the filters become too dirty condensation can be seriously ********. Check to see if the fins require any attention; they can be cleaned very carefully with a toothbrush and some water usually. If the buildup has become severe special chemicals need to be used on the unit- not something recommended the average person attempt. If the fins are clear check other airflow issues. Dehumidifiers generally need a period of 3 days to balance an area properly when functioning and sized appropriately.
Sep 22, 2011 | Haier Dehumidifiers
Have a pentair ccp320 filter.brand new last year.pool water has been cloudy for two weeks.water is balancedexcept akalinity is high at 200.suspect filter problems.water was clear for a month.cleaned...
Total alkalinity can be lowered by adding muriatic acid or sodium bisulfate. Acid may be added in doses of up to 1 quart per 10,000 gallons. Total alkalinity tests and further required additions of acid can be made every 2 hours.
Jun 28, 2011 | Pentair Clean & Clear Plus Ccp320 Pool...
Pool filter return keeps stopping
If you have cleaned the fingers in acid you may have to replace the socks on the fingers.
Jul 21, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Cooling has stopped
Apparently the freon has escaped or the metering device for the freon is plugged up. Either way, it's expensive. Check your warranty for "sealed system" repairs.
Jul 26, 2008 | Frigidaire Heating & Cooling
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
