Question about Murray Garden
How to replace blades
How to safely replace the old blades with new one
    Master:
  • 301 Answers
Any lawn motor place would have them, or you can goto Home depot or lowes too.
Posted on Apr 07, 2015
How do I change a saw blade on a scroll saw
Which Scroll Saw are you using...there are multiple brands and multiple models. Help us out and tell us which one you have.
Most of the time there is a clamping mechanism that holds the top of the blade in place. Many models have a door or some access point to the lower end of the blade, too, which you'll have to get to as well.
You'll also usually find that there is some type of blade tension device that needs to be released and then reset before you can install and use a new blade. Make sure the new blade is the same length as the old one, also, make sure that it's the same type of blade, some have a small pin top and bottom, some do not.
Finally, check out YouTube and see if anyone has put up a video for your brand of Scroll Saw. May be the answer.
Good luck and be safe.
Oct 09, 2014 | Saws
How do I change the blade on model #17224 saber saw?
Are you talking about a reciprocating saw? What brand? If this is what you're referring to, then there is usually an Allen style set screw at the base of the blade. Loosen the set screw with an Allen wrench, and replace the blade. Retighten the set screw and cut away.
Oct 06, 2014 | Saws
Jammed my 6230 bandsaw during a cut and now it won't start. Are their fuses I can replace?
Go to Milwaukee Tool website and try to check if you can download a manual or electrical diagram there. You can call or email them. Check the motor capacitor.
Are you using an old or new band saw blade? If it's old/dull, try different blade. If it's new, the weld might be really bad. Old Blade and Bad weld can cause the blade to jump off. I purchased band saw blades on www.sawblade.com . Great quality blades; they have porta band blades. Call them.
Oct 23, 2013 | Milwaukee Tool Milwaukee 6230 Deep Cut...
New to table saw use, have my husbands old 10 craftsman, was learning to rip with it doing fine, then it started to bog down during cut until the blades stops, moving. put on a new blade and noticed...
If I understood correctly, you started using your husband's table saw and while ripping boards, you managed to stall out the blade AND motor?! If that's the case, you probably have a very dull blade and are binding your board on the blade. Neither is safe and it sounds like trouble is brewing.
First and foremost, get someone to show you how to safely and properly use and adjust the saw if you are new to wood working and power tools. That saw is capable of turning your lumber into a high speed missal if you do things improperly.
It also sounds like you tried installing a new 10" saw blade. Changing the blade requires 2 wrenches. One to hold the arbor and one to tighten the nut. The blade itself should rest on the arbor between two large washers. Also make sure you install the blade so the front face of the cutter teeth face you and rotate toward you. Make sure the saw is unplugged when changing the blade and never turn on your saw with a loose blade.
Oct 20, 2013 | Craftsman 10" Table Saw
How do you replace the belt on the mower
Without looking in the manual, I would suggest removing one of the blade housings. First, jack up the tractor from the middle of the rear axle. Use some jackstands as a safety net to keep the tractor from falling, I usually use two jack stands for total support and be sure to scotch the front wheels so that the tractor is sturdy, unable to move and safe. Next, note the routing position of the belt. I have replaced 2 of these blade housings already from shearing them while mowing. There should be 4 bolts running from the top of the deck thru the blade housing. When this housing is removed take the old belt off and reinstall new belt. Reinstall the blade housing and you should be set.
Jul 15, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
I REPLACE CONDENSOR FAN ON A LENNOX BUT THE FAN IS OVER HEATTING AND STOPS& COOLS DOWN AND RUNS
Did you replace the fan blade or the fan motor? If you replaced the fan blade, is it exactly the same blade as the old one? If it has more blades, or wider blades, or if the blades are at a different pitch than the original, it is capable of moving a greater amount of air, but the old fan motor is not big enough in Horsepower to do the extra work. Thus, you should change the blade again to one that is exactly the same as the old one. If it is a window unit, you could try running the fan on a lower speed and it might work.If you replaced the fan motor, you must check to make sure that the new motor is exactly the same as the old one. You also could have it wired wrong, so you must check that also.
Jul 05, 2010 | Heating & Cooling
How do you replace a new wiper blade on 2008 kia sportage
Walmart and some Autozones and Oreillys will install the wiper blades for free. You can watch them do it so you can do your own afterwards.
Feb 06, 2010 | 2007 Kia Sedona LX Minivan
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
How do I replace the blade of a lufkin fluorolok tape?
Pull the old blade ALL off the way out until you see where the spring attaches to the blade. Twist the old blade off while carefully holding on to the spring. re-attach the new blade and slowly let it back in. Unless you cut the old blade and heard the spring make a unwinding sound, then you are pretty much screwed unless you want to take it apart and waste about 4 hours of your life trying to rewind the spring and then finally giving up and buying a new one for about 10/12 bucks.10 bucks divided by 4 hours equals $2.50 an hour.......no thanks ......I'll just go buy a new one. PLEASE RATE MY ANSWER.
Aug 28, 2009 | Measuring Tools & Sensors
Garden Logo
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
