Question about Hotpoint Refrigerators
Hotpoint fridge clicks before starting
GSS25JFMC - the fridge goes into clicking mode... for hours (5, 6?) not able to turn on (sounds like a relay switch). Then it suddenly turns on and works for hours (10?) then again unable to turn on.. then again fine. I looked in the back, the board seems ok. the fan works. I cleaned the coils.
  • Hotpoint Master
  • 473 Answers
You have a possible compressor relay going bad or something like low house power could cause that. Also the mother board could be going bad without seeing any problem. Electronic boards sometimes go bad without being able to actually see it. The compressor part of the board will sometimes burn a spot on the mother board but can only be see on the back solder side.
Posted on Apr 08, 2015
Hiya,i have a hotpoint fridge freezer ffa91 and the fridge is no longer getting cold.The compressor seems is hot but cant hear the normal noises coming from the fridge.The digital display shows an arrow...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 12, 2011 | Hotpoint Refrigerators
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
4. Wait one hour.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Clicking sound in back of frig, isnt cooling
The clicking is related to a relay next to the compressor. Something is not allowing the compressor to run, perhaps an overload, broken motor, relay failure, etc.
It's a good idea to get ice to save the food, don't wait more than 4 hours to see if the fridge will cool by itself. Avoid food poisoning.
As the symptoms are too broad to determine exactly what is wrong, the first thing to do is to replace the relay. If the problem continues, you may need to contact a technician.
Nov 16, 2009 | Hotpoint HSS25GFP Side by Side...
HotPoint fridge clicks and the fan doesn't turn
14 vac indicates a bad motherboard.Clicking could possibly be a bad start relay on the compressor.
Relays are inexpensive. I would replace the relay and hope for the best. Next step would be the motherboard that GE has had trouble with from day one
Jul 21, 2009 | GE Refrigerators
Freezer and fridge are not cooling but we hear the sound of the refrigerator
your defrost heater or timer is not working . rotate you defrost timer until it clicks and check if its is defrosting if it is let it defrost for about 10 mins and turn the timer some more to take it out of defrost. replace timer
Jun 02, 2009 | Hotpoint HSS25GFP Side by Side...
Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
May 20, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Ge hotpoint fridge
When replaceing the heater, did you completly defrost the unit, meaning a clear, no frost on the evap coil? The other problem could be the bi-metal or timer. If the is a clicking sound, is from the compressor? Then unplug the unit for about 15 mins and see what it does.
Aug 30, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Refrigerators Logo
44 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
