One of the pumps stops and starts to surge on and off after about 10 or 15 minutes a code flashes time and program I can't shut the pump off without killing all power
  • Washing Mach... Master
  • 5,323 Answers
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Posted on Apr 13, 2015
jackboy
  • 2985 Answers
SOURCE: Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Posted on Jul 31, 2007
  • 1294 Answers
SOURCE: Indesit W101 Washing Machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 31, 2007
SOURCE: flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Posted on Oct 16, 2008
  • 3 Answers
SOURCE: "F" error code in WTW6600SG1 Cabrio Washer
inside the control board panel or taped inside of cabinet wall are the tech sheet with trouble code definitions and procedures to trouble shoot washer
Posted on Apr 16, 2009
caroldon
  • 17130 Answers
SOURCE: Start/Pause light flashes, won't start. No error code. Pump or hose blockage?
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jun 29, 2012
Kia Rio 2005 is Surging... just had Heads rebuilt after timing belt broke.
could be an ecm program problem
try and get a scanner to reset the ECM / cpu program as it can be corrupted after a long period of not battery connected
another possible problem is that the fuel pressure regulator / pump or possible dirty injectors
the relation to the head problem is , sitting for long periods can introduce dirt into the fuel lines or allow diaphragms to dry out
if your neighbor is mechanically savvy get a fuel pressure gauge to test fuel pressure as well
Oct 22, 2016 | 2005 Kia Rio
I changed the hydraulic gear pump on my bobcat and had an AHC code light up. Before finishing my repair I started the machine and checked for hydraulic fluid leaks by letting it idle for a few minutes
Disconnect the battery for 30 minutes. On cars , this resets the computers. Back to factory specs. Worth a shot. If the sensor worked before, most likely it is good.
Jan 22, 2015 | Cars & Trucks
On my 2001 Lincoln ls 3.9 security light on dash still flashing rapidly for a minute then pause 1 flash pause 6 flashes with key on. Now when I put key in ignition the rpms and speedometer gauges star
Well I am a certified mechanic and I would pull the air cleaner housing open the throttle shoot some carb cleaner in it and if it starts even if only for few seconds your fuel pump is bad. If it doesn't than you need to scan the car with a scanner for no start codes. You can rent a scanner at most automotive part stores for a deposit and when you return it undamaged you get your money back. Usually costs nothing. But if you don't have any pressure on the fuel rail that is most likely your problem. You can clear all the dashboard codes and lights with a scanner if they don't straiten it out on its own. Disconnect battery for a few minutes sometimes that will clear old codes. Only clear codes if you have found out that the fuel pump was bad otherwise you'll need them codes for figuring out the no start problem. Bryan ASE master certified mechanic.
Jan 05, 2015 | 2001 Lincoln LS
Washing machine stop and start flashing o2f
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
98 chevy cavalier cranks but wont start changed fuel pump,computer,crank shaft position sensor and the theft system light is staying on
try to start the car, than the anti theift would shut the car off. you wait ten min with the key on, until you see the anti theift flash or disapear. than turn key to off position and try to start it. this will reprogram the computer.. Good luck.
you can also try disconnecting the battery for 30 minutes
Oct 07, 2009 | 1998 Chevrolet Cavalier
F2 code... stops part way through cycles.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the electrical connections at the pump and make sure the pump is running.
Jun 26, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Intex pool filter/ pump just stopped working
Try giving your pump more air circulation.
Turn off pump when not around it.(should only need to run for around 3 - 4 hours on a small (kid) pool 6 - 8 hours for standard house pool
You could put you pump on a timmer - set shut off time to just before you pump shuts down.
Check you pump (when not conected to mains power) - get some WD40 into it - (salt and metal no like each other)
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Pool pump starts & stops on its own outside of programmed run
There are several potential problems:
  • freeze protection circuit causing pump to start - could be a bad outside air temperature sensor.
  • It is possible the new relay is bad.
  • There could be a short in the control wires to the relay
  • old programming shadow stuck in memory (not likely since you changed the boards)
Yes, the starting and stopping can harm your pump.
Jun 04, 2009 | Pentair 1hp Whisperflo Pool Pump In -...
Continous surging and stalling
Per your description, I would suspect a fuel pump issue. When the fuel pump is running the pump impeller heats up. On an older pump the impeller can begin to seize up and momentarily stops and starts. Some times it just stops and has to cool down for a couple of minutes, then is ok for a while.
To test this theory, when the engine stalls and stops, your mechanic can use a rubber mallet and hit the bottom of the gas tank, this will free the pump impeller and the car will start again.
Or, have him install a fuel pressure gauge and go for a drive. If the pressure begins to fluctuate and drop, you know the pump is causing the issue.
Good luck, let me know.
Regards,
Apr 30, 2009 | 1990 Buick Reatta
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
