Question about Panasonic Televison & Video
I have a Panasonic TC-P50ST30 & get a 14 blink error code. Question is in buying a replacement part.
From what I saw online is if the P2 connection on the power supply board gave 0 ohms that the power supply board was bad. At first it was ok by showing it had 1.5 ohms for 5 secs then it drops to 0, then it takes a few minutes before anything will show again but then it drops back to 0, is this a bad power supply board? Additionally if I go on to test the SC board with the power board disconnected from it and I get the same thing 1.4 ohms then it then drops to 0 and have to wait a few before it shows back again for 5 secs. Also the TPSC1 shows absolutely no ohms at all with testing su and sd disconnected at separate times as instructed in a video I watched. Would this be a bad SC board as well? Here is the link to the video I watched to try to repair this. https://www.youtube.com/watch?v=iHBIiRxhe0w Thank you
  • 7 Answers
SOURCE: No power
I would guess it's the power unit for the TV itself.
If it's still under guarantee I would have thought you should be able to get it replaced.
Posted on Feb 19, 2009
  • 4 Answers
SOURCE: Mi F003 show the error NOT ALLOWED TO DIAL tis
Guys I had the same problem with the k599 Sciphone and none of the solutions found on the internet helped me. New chinese models tend to restart after testing is over and this results in turning the wifi application on. So I spent many hours on thinking how to bypass this function and this morning I woke up with an idea that really worked!! The steps are quite similar with the ones followed to debug older models:
put 2 chips on cell
Disable WLAN.
1-enter in factory mode *#3646633#
2-go to RF Test Tool
3-choose GSM, confirm OK!
4-go to Power scan
5-Select Band DCS1800 click OK
6-the cell frozen
7-wait for 3 minutes testing
8-while testing connect to a pc using the USB cable (do NOT select ANY of the options appearing on the cell screen)
9-Click the CENTER button of the cell until you go back to principal menu
10-go to settings/network settings and choose GSM Preferred or any other option (except WLAN only!!)
In this way the cell does not reboot, and the wifi application stays off, so the option can now be changed...
Hope this helps!
Greetings from Greece!
email me to akiss_bd@hotmail.com if any questions
Posted on Sep 11, 2009
toolkits
  • 1099 Answers
SOURCE: I have a Panasonic TH-42PX80U TV. When I power up
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Oct 04, 2010
eagle338
  • 4889 Answers
SOURCE: My LCT3201AD performs a continuous
Last week I had seen exactly the same problem with my friend's tv(different brand though its a BRavia LCD). Could fix it by replacing a few capacitors on the power supply board. Cost me approximately 15$ for the 4 of them. If you are good at fixing stuff then you might wanna give it a shot. Have a look at the tops of the capacitors to see if you find any bulged or cracked ones. Replace any of them found with those of exactly same specs and temperature rating.
PS: This repair carries a high risk of electric shock if not done correctly. The capacitors hold residual voltages and have to be discharged before working on the board. I would not recommend that you do it yourself unless you have the know how of electronic circuits. A service man might be the way to go if you have never worked on electronics before.
Posted on Oct 31, 2010
  • 347 Answers
SOURCE: I made a short video demonstrating the problem:
it is definately the main board buddy the power board will be fine what it is there is a common fault with this model of tv the boards are faulty on the earlier models ive seen this plenty times before i am a tv technician
Posted on Jan 20, 2011
What does a 3 blink code mean on Panasonic TC-P65VT60?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Feb 01, 2017 | Panasonic TC-P65VT60 65" Plasma TV...
How do I safely replace the A-board on a Panasonic TC-42PX24 plasma TV? (Or, how do I confirm that the A-board is truly the problem component?)
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 17, 2016 | Panasonic Tc-42px24 42 in. Plasma TV
I have a Panasonic TC-P65ST50 which recently began shutting down and displaying 7 blinking lights and 8 blinking lights. Most of the time 7 blinking lights are displayed.
Feb 25, 2016 | Panasonic TC P65ST50 - 65" Class 64.7"...
I have a Panasonic Plasma TV Model TC-P55GT31. I got the 7 blinks of ***** and the TV is dead. Research online suggests it is likely the SC board.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jul 17, 2015 | Panasonic Televison & Video
Panasonic viera tc-p65vt50, lite blinks 12 times and then starts over.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 22, 2015 | Panasonic Televison & Video
Panasonic TC-P55ST30 had 14 blinks. I followed the shop Jimmy testing video and there were no shorts. The next step was to power on and push button and if light flashes you need an Aboard if it's so
Jan 21, 2015 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
My LCD Panasonic TC-L42U12 blinks 14 times does some one have the Error code list to see what I need to fix?
13 blinks means a communication error on the A board (main board). The part number for the main board is TXN/A10PYHS. I would recommend TSM for a replacement board. Good warranty and price.
www.tristatemodule.com
Nov 04, 2013 | Panasonic TC-L42U12 LCD TV
Tc-p50g20 4 blinks
My panasonic TC-P50G20 does not power on, just I have 4 blinks on my powericon1.png indicator light. What error does that mean?
Jul 24, 2013 | Panasonic Tc-p50g20 Viera G20 Series 50"...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
