Question about Garden
Motor slowed down after 20 minutes and almost died, oil got very hot!
Changed oil, fuel pump and coils
    Top Expert:
  • Garden Master
  • 12,540 Answers
Check motor cooling fins and make sure there is unobstructed air flow over them.
The motor slowing down after 20 minutes is caused by overheating of the pistons and metal expansion causing excessive friction which if uncorrected will eventually cause motor to seize.
Make sure that oil is being properly distributed to parts for cooling and lubrication. Clogged passages could be at fault with poor lubrication.
Posted on Apr 08, 2015
    Master:
  • 301 Answers
Check the gap on the spark plug too.
Posted on Apr 07, 2015
Engine stops running when hot.
Sounds like the coil is breaking down when gets hot.
Jun 01, 2012 | John Deere Garden
Car started to act like it was running out of gas then died,oil was low filled it,went to start it ,when I do it takes a minute to kick in.motor is turnning ,once it starts it acts like a knockin for a...
Its posible it could be the cam shaft or crank shaft positioning sensor you may be better off renting a OBD 2 scanner and get a code that would get you closer to the problem.
Jun 18, 2011 | 1998 Chevrolet Lumina
1993 dodge caravan 3.3 v6 on days when outside temps are higher than 70 degrees after driving for a while if rpm's get below say 1200 car will stall out and after 20 mins. it will restart but will stall...
What does it do, if you try to accelerate when this starts to happen? If it dies,sputters or is sluggish, I'd start by changing fuel filter, and if that doesn't help, have fuel pressure tested when (if at all possible) this begins to happen. Had similar problem, winter was fine, hot weather it would die, and restart after 20 minutes or so, then go a fair distance again, then same thing. Fuel pump was on it's way out and when it got hot, fuel pressure would drop. First thing in the morning when fuel in tank and pump was cool, ran like a charm, but on way home from work, after sitting on a hot day, fuel got warm/hot, and pump heated up and that's when it started. Carried a fuel pressure gauge with me. Fuel pressure when cool, was 49 psi, and when it got hot, eventually dropped off to 2 psi. Sat for 20 minutes, jumped back up to 49psi, took off for home,then would eventually get lower and die again. Changed pump and filter, all was well. Try filter first, you have nothing to lose, and it should be changed if pump replaced later anyway.
Jun 24, 2010 | 1993 Dodge Caravan
2000 vw cabrio runs normal and shuts down, takes 5 to 20 minutes to restart, engine cranks but doesnt start, changed ignition coil, pulled diagnostic codes getting short to ground codes on cylinder...
On some models, the Engine Control unit has a power supply relay. These relays some times get internal dry solder points. After driving for some time the the solder will get hot and separate. When it cools down it makes contact again. You will have to replace this relay or open it up and re- solder the solder joints. The relay is usually located on the main relay station in position 3. the relay station is located behind the right dash panel.[right hand drive vehicles]. You may need to refer to a manual for your specific model to find the exact location of the relay.
Jun 04, 2010 | 2000 Volkswagen Cabrio
90 VOLVO Runs, dies, then won't start. Wait then runs then dies
FUEL PUMP GETTING HOT, check fuel pressure, check for spark at the coil sounds like a heat problem, got a blow dryer? when it comes to fuel pumps go to NAPA GOOD PARTS, on the left front door fuse panel jump hot 12vdc to to pump, check for voltage there aswell when it dies
Sep 19, 2009 | 1992 Volvo 240
Runs for 20 minutes, gets hot and shuts down. Still has spark
I had the same problem, took to a benz dealer, it was the fuel pump relay, cost for repair $200.
Jun 25, 2009 | 1989 Mercedes-Benz 300-Class
1989Bronco cuts off
Replace the Lift Pump in the gas tank ( s ) and the pusher pump.. Thanx
Mar 10, 2009 | 1989 Ford Bronco
89 GMC S15 V6 going down the road and motor dies
Did you change your fuel filter? What about the air filter? You nay also have a bad plug wire. It may need a tune up. I do my own.
Nov 18, 2008 | 1988 GMC S-15
Motor shuts down
Have you checked/tested the fuel pressure? sounds like a bad pump and or plugged fuel filter, check the pressure, if it is low replace the filter, if that still doesn't help you will need a new fuel pump, it is located in the fuel tank.
Aug 15, 2008 | 1999 Chevrolet Blazer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
