Question about Samsung WF419AAW Front Load Washer
My washer will not spin full speed and shows 3E error code.
OK. Initially dryer showed 3E error and would not spin at all. I replaced motor rotor and hall sensor. I thought i purchased rotor/drive motor/hall sensor kit, but it only came with rotor and sensor. After installing, motor runs slow to medium speeds but wont go real fast. Before it gets into a cycle, it stops and shows 3E again. Couple questions . . First do I need to replace to magnet outside portion of the motor to truly rule this as the cause or can i leave that as? Or is this something that should always be replaced together? I also have a theory that something got in the drum or broke into it because when I spin it manually, it sounds like something is bouncing/clangling in between? Its not coming out through the drain, so i dont know if something is trapped and preventing it from hitting higher speeds. Is this suppose to spin noiselessly when done manually? Appreciate any help/advice you may give. Im thinking about separating the drum to look inside but would rather avoid this if there is a simpler solution. Matt
    Master:
  • 301 Answers
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
3E error during rinse cycle on Amana NFW7200TW washer
E3 Error: Machine control is attempting to drive the motor but is not seeing any tach response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). The hall sensor is a circuit in the motor. the motor will need to be replaced. Here is a link to the motor.
Oct 18, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
Samsung Model WF220 won't spin after it fills with water. It displays Error code 3E.
This video will help you diagnose the fault on Samsung Model WF220 3e error codes and the video will help you solve the problem
Sep 08, 2012 | Washing Machines
Ok my LG front loading washer agitates but when it comes to spin it makes a very irritating high grinding noise and does not spin. There is no error displayed but that may be because I stop it before it...
I have a similar problem. The washer was showing error code UE, but would tumble when empty in test mode, but would not spin and made a grinding noise. The bolt that attaches the rotor to the motor was loose and the rotor was spinning on the spindle that rotates the drum. I tightened the bolt, and it spins when empty, but still gives a UE error code when full. Remove the rear cover and check the tightness of the center bolt.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag front loading washing machine
3E = Drive system is not working correctly. Bad windings, speed sensor, wiring connections or Control Board.
Jun 12, 2008 | Maytag MAH2400A Front Load Washer
Samsung WF419AAW Front Load Washer Logo
149 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
