Question about Intel Science & Laboratory
Intel play microscope qx3+ for Windows 7 Professional
Seems to be connected to computer, but can't get video to work. Functions of microscope available on screen (slow), but no picture.
  • 72 Answers
SOURCE: QX3 micrscope dont work with Vista
Uninstall the existing Intel microscope software and then follow the steps below.
Instruction for installing the QX3 or QX3+ Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Posted on May 24, 2009
  • 72 Answers
SOURCE: vista driver for Intel QX3 Microscope
Joshi_Z
  • 567 Answers
SOURCE: I have a Intel Play
Hi
I looked up for the drivers for your Intel Play QX3 Microscope on Intel's website.You can check this link
For the time being the driver has not been released for this device.Last driver update was on 8/28/2006 which was before the launch of windows 7.We need to wait for the compatible drivers or use this device on windows XP platform
Thank you
Posted on Oct 01, 2010
  • 72 Answers
SOURCE: The software keys into the
Here are the instruction for installing the Intel QX3 (or QX3+) Microscope with Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Windows 7 or Vista.
Before you run the programs below, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/qx3plus or
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems〈=eng
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
http://tinyurl.com/IntelQX3driverXP or
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Posted on Jul 04, 2011
  • 72 Answers
SOURCE: need qx3 drivers for windows 7 64 bit
The Intel QX3 is not compatible with 64 bit operating systems. It will not work. Sorry.
You can either reinstall Windows 7 as a 32-bit version or purchase a QX5 model which is compatible with Windows 7 64-bit.
-Mark
Need driver for intel qx3 microscope with windows 7
The Windows 7 Files are now located at:
QX3 Files for Win7
Comments and suggestions to mmehall [at] yahoo.com
Jun 16, 2014 | Intel Play QX3 Monocular Microscope
Windows 7 driver
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
Step 1. Download and install the QX3PLUS.EXE software from:
http://tinyurl.com/QX3-Win7-Files
IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok".
Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run.
If you get a message that the microscope is not plugged in, quit and restart the program.
If the program hangs or crashes, reboot the computer, then restart the program.
Jan 19, 2014 | Intel Play QX3 Monocular Microscope
Digital blue qx3 drivers
Here are the instruction for installing the Intel QX3 (or Digital Blue QX3+) Microscope with Windows 7 or Windows 8.1. You must be using a 32-BIT VERSION of Windows 7 or 8.1.
Note: The QX3 is not compatible with 64-bit versions of XP, Vista, Windows 7 or 8.
Step 1. Download and run the QX3plus.exe program from:
http://tinyurl.com/QX3-Win8-1
After the program installs, uncheck "I would like to view the README file." Click "Finish".
Step 2. Download and run the qcodinstl.exe program from:
If asked about NTVDM, click "Install this feature" then click "Close"
Step 3. Download IntelQX3driverXP.zip and save (do not open) the file from:
Step 4. Now, plug in the microscope. The driver should load silently.
If the "Found New Hardware" wizard appears and you get a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Right-click START - Select "Device Manager"
b. Right-click on the Intel QX3 Icon and select "Update Driver Software", select "Browse my computer for driver software"
e. Browse to the Download folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Aug 20, 2013 | Intel Play QX3 Monocular Microscope
May 02, 2013 | Intel Play QX3 Monocular Microscope
Qx3miroscope driver for windows 7
http://download.cnet.com/Intel-Play-QX3-Microscope/3000-2110_4-104288.html
worked for me Win 7 64 bit. May need to use compatibility mode (look it up separate problem if that's the case)
Dec 11, 2011 | Intel Play QX3 Monocular Microscope
I have a Intel Play QX3 Microscope and a I can't find the driver for Windows 7. What can I do?
Hi
Thank you
Oct 01, 2010 | Intel Play QX3 Monocular Microscope
Need qx3 drivers for windows 7 64 bit
-Mark
Jun 23, 2010 | Intel Play QX3 Monocular Microscope
Science & Laboratory Logo
281 people viewed this question
Top Intel Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
