If I have $8,800 and I subtract $960.00 what is my remainder
    Sergeant:
  • 315 Answers
$7,840 I imagine.
Posted on Apr 07, 2015
Convert temperature from Fahrenheit to Celsius
Take the F temperature, subtract 32, then divide the remainder by 1.8 to get Celsius.
Proof since boiling point of water is: 212 F = 100 C
F 212 - 32 = 180
180 / 1.8 = 100 C
Oct 31, 2016 | Office Equipment & Supplies
How many times does 182 go into 2332 and what is the remainder
I hope that I am in time!
Let's do it with long division first.
___12______________
182 ) 2332
182
512
364
148 <- this is the remainder
Now, let's try with a calculator.
______
2332/182 = 12.813186
To get the most accurate number, on your calculator subtract 12
_______
from this number and we get 0.813186 . Now multiply this number by 182 to get the remainder, and I get 148.
I love it when I get the same answer both ways;)
Good luck.
Paul
Mar 24, 2015 | Office Equipment & Supplies
What is 67,872 divided by 24, step by step?
First, find out how many whole times 24 will go into 67
67/24 = 2 with a remainder that we don't care about. Write down 2
Next, multiply that answer (2) by 24 2 X 24=48
Subtract that 48 from 67 67-48=19
bring down next digit (8) append to the19 198
divide 24 into 198 198/24=8 Write down 8
multiply that answer by 24 8 X 24 =192
Subtract that 192 from 198 198 - 192 = 6
bring down next digit (7) append to the 6 67
divide 24 into 67 67/24 =2 Write down 2
multiply that answer by 24 2 X 24 = 48
subtract 48 from 67 27-24=19
bring down next digit (2)append to the 19 192
divide 24 into 192 192/24 = 8 Write down 8
multiply that answer by 24 24 X 8=192
subtract 192 from 192 192-192=0 You're done!
Your answer is the numbers you wrote down after the divisions = 2848
2 8 4 8
24 ) 67872
- 48
198
-192
67
- 48
192
- 192
0
Oct 15, 2014 | Office Equipment & Supplies
Luke wants to find the difference 175 - 134. He has subtracted the hundreds and tens so far. What is the sum of the two numbers he has subtracted? How much does he still need to subtract?
SUM means adding not subtracting. so if you were wanting to add the total (the sum) of the amounts of the hundreds and the tens would be 170 plus 130 which would be 300 but the remainder from subtracting 130 from 170 would be 40. That would leave the single units 5 minus 4 of which the remainder is 1. So, the remainder from subtracting 134 from 175 is the reminder of subtracting the one hundred from the one hundred which is zero added to the remainder of subtracting the tens (70 minus 30) which is the remainder of 40 plus the remainder of subtracting the units of 5 minus 4 which is 1. So you need to add the 0 and the 40 and 1 which is the remaining sum of 41.
Sep 19, 2014 | Office Equipment & Supplies
Remainder
The quotient is easy. Since the calculator drops any fractional portion when in base mode, simply do the division. For example, to get the quotient of 5 and 3, divide 5 by 3 and see 1.
The remainder is a bit harder. Subtract the product of the quotient and the divisor from the dividend. For example, to get the remainder of 5 and 3, first calculate the quotient as above. Then subtract 1*3 from 5 and see 2.
Apr 27, 2013 | Casio FX991MS Scientific Calculator
How to calculate mode with caso fx-991ES
MOD simply calculates the remainder that is left over after dividing by the MOD parameter.
For example, 10MOD7 = 3 since you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg 389487MOD31 you start by dividing 389487 by 31, which gives 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD calculation has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculators working capacity.
An alternative method is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Feb 23, 2013 | Casio FX991ES Scientific Calculator
How to find remainder as a solution in CASIO fx991ES
Finding the remainder from a division calculation is often referred to as using the MOD function, though this isn't available directly on the fx-991ES.
To obtain the remainder, for example when dividing 10 by 7, you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg when dividing 389487 by 31 (equivalent to 389487MOD31) the division gives an answer of 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD or remainder calculation involving integers has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculator's working capacity.
An alternative method which avoids the rounding of the fractional part is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Dec 16, 2012 | Casio FX991ES Scientific Calculator
How to get it to subtract
Type in your first set of numbers and the press the red "minus" key. The "*" key will give you your remainder or total.
Dec 27, 2010 | Canon P170-DH Calculator
How to calculate 24124 mod 19937 in casio fx-991Ms calculator
The MOD function simply returns the remainder that is left over after dividing the two numbers.
In this case, its possible to see quite easily that only 1×19937 can be taken from 24124 before the remainder is less than 19937. The MOD function is therefore the same as 24124 - 19937 = 4187.
In cases that are less obvious, do the division, ie 24124 ÷ 19937 = 1.210011536[34]
[The last two digits are hidden on the display but still used in subsequent calculations].
Then obtain the fractional part by subtracting 1 to give 0.210011536[34]. Then multiply the answer by 19937 to give 4187. Assuming that you haven't cleared the screen between each section of the calculation, the screen will show "Ans×19937 [=] 4187".
May 10, 2010 | Casio FX-115MS Plus Calculator
We have an older model hotbu .....a Jacuzzi JS88-0882. It is to be supported underneath by a frame of 2 X 4's, but the pages showing the exact design of this is missing from our old manual. We have moved...
sit the tub on the ground and measure the distance from the floor to the bottom of the tub lip, My tub was 22 inch. next subtract tho top surface. Iin my case I used 1 1/4 Marble, 1/2 backer board, and 1/4 thin-set, and 1/16 roof felt. subtract the height of all the above from 22inch. and the remainder will be the height of your 2X4 frame. Make shure the 2X4 frame is level
Mar 08, 2010 | Home
k24674
