Hoover VHD shows E03 error. I cleaned filter, checked drain hose, squeezed black sump for blockages. What is the issue? Have noticed water goes in machine but detergents still in drawer.
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Sump hose probably blocked. Tilt washer backwards so u can get under it. Pipe comes from bottom of tub too filter housing, squeeze it you will be able too feel if anything is stuck inside it, simply remove pipe at one end and remove blockage.refit pipe and test
E03 indicates the appliance isn't draining quickly enough, or, doesn't know that it's drained.
The first part would be restrictions in the sump hose, pump, drain hose or house drains. It could also be a faulty pump. You would need to check all of these parts to ensure it's all clean and clear.
The second part would suggest that there is debris in the pressure chamber causing intermittent blocking. Unplug the appliance and take the rear panel off. You'll see a plastic fitting in the sump hose with a thin tube attached to it. This is the pressure chamber, take it out and clean out the pressure chamber. For getting
required parts you can get it from the online site likewww.repairclinic.comThanks. keep updated for any more
query.you can rate this solution and show your appreciation.
Error code F05 means pressure switch jammed on full.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum
Remove and clean filter in side hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem
Please rate my solution.
Thankyou.
It sounds like you have a partial blockage somewhere..
Remove rear panel.
Remove large black hose onto drum.
Check and clean filter inside hose.
Remove drain hose, and check for restriction here as well.
Thanks.
Hi, OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended. Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace. Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
