Question about Icom IC-718 Base radio, HF, 100W
No sound without pre amp on, then very, very faint sound
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
Check the voltages of Audio Amplifier.
Posted on Jul 11, 2016
How do I adjust the audio settings on the SHT-6200 amp. Music is playing faint and in the background, not full and robust
If you are just using a record deck, then the answer is that you need a magnetic cartridge pre-amp to make it work.
However if you are having the problems on all settings, then it sounds like the main power amp has failed.
Jan 31, 2017 | The Audio Players & Recorders
My amplifer does not have a pre in connection what can I use to substitute
You can use any spare connection, such as tape, aux, CD. However you will have to purchase a magnetic cartridge pre-amp, otherwise you will only hear a faint sound from the deck.
Only connect the deck to the pre-amp. If you are short on connections, then you can get a switching box, which will allow several devices to be connect to one socket on you amp.
Oct 27, 2016 | Audio Players & Recorders
I have a JVC QL-L20B turntable, hooked to receiver directly and plugged through cable, cannot get any sound except very faint from turntable itself, any suggestions.
SINCE I DON'T HAVE THE TURNTABLE IN FRONT OF ME AND NOT BEING FAMILIAR WITH THIS PARTICULAR TURNTABLE, I CAN GIVE AN EDUCATED GUESS. WITHOUT GETTING INTO THE CONFUSING ELECTRONIC SPECIFICS, ABOUT PREAMPS, ETC. REMOVE THE TURNTABLE PLATTER. UNDERNEATH IT, IF I'M CORRECT, THERE SHOULD BE A SLIDE SWITCH. IF THERE IS, SLIDE TO THE OTHER POSITION FROM WHERE IT IS CURRENTLY. PUT THE PLATTER BACK ON, TURN ON YOUR SYSTEM AND SEE IF THAT SOLVES YOUR PROBLEM. IF NOT, YOU MAY NEED TO BUY A PREAMP FOR YOUR TURNTABLE. HOPE THIS SUGGESTION HELPS
TIM
Jun 13, 2014 | JVC AL A158BK Turntable
Why is there no music being transmitted from turntable to sound system?
If the amps connected to the deck have no dedicated "phono" socket / setting you will only hear weak sound. However you can get a magnetic cartridge pre-amp. This connects between the turntable and amp and makes the signal the same level as what would come off say a tape recorder.
Apr 29, 2014 | Teac P-A688 Turntable
I have this turntable but can't get sound from my technics dv290 . There are 2 leads which I have plugged in the back . I can fainted hear the record.every thing else works well.what do I need for my...
I rather suspect that your amp might not have a "magnetic cartridge pre-amp". If you check your instructions book it should state if the amp has a dedicated "phono" socket with inbuilt pre-amp. If it does use that. Otherwise you can buy a pre-amp online that will do the job.
Aug 12, 2013 | Technics SL-1200MK2 Turntable
My NAD C320 outputs a very low sound volume
Hi there I have a C340 that has similar problem, you must have bought this from ebay, lol.
Nad made a mistake on the C range, the pre - power link can be shorted out. if the pre is shorted out it takes out the pre amplifier stage, I have managed to get the right channel working, I will keep you informed what is the cause of the left channel. I have replaced the pre-amp IC and a couple of Jfets and transistors. Once I have repaired the Amp I could repaire yours if you like???
Apr 14, 2012 | NAD C320 2-Channel Amplifier
0ne channel sound other very faint
You still need to determine if the main amp is at fault, before takling the turntable. Does the amp have seperate sockets for the turnatable, if yes then inside the amp it will have a pre-amp just for the the deck, which no other device will go through. This can be easily tested. First find it, by tracing the wires from the phono imput to the first PC Board you come to. This should have the pre-amp on it. Touching the left and right inputs (one at a time) to it should cause it to buzz. If they buzz at the same volume it's OK. If not there's a fault on it.
If that test is good then the turnatable is to blame, starting with the obvious fault of the cartridge. Other faults include broken or poor connections, plus a fault in a pre-amp on the turntable. You can test this by the same method as above.
Nov 30, 2009 | Audio Players & Recorders
No sound from LP on Sony turntable connected to Sony HCD RX 70
You might need a preamp if you turn it up full volume and can faintly hear the music in needs a pre-amp to boost the signal .
Aug 04, 2009 | Sony Audio Players & Recorders
NAD C740 no longer reproducing music through loudspeakers
what was your amp? ic or transistorized? the output transistor of your amp may be opened, mostly it will short but because u still hear sound, maybe open and only the driver transistor are working. replacing output transistor or IC could solve the problem.
May 14, 2007 | NAD C320 2-Channel Amplifier
Icom IC-718 Base radio, HF, 100W Logo
127 people viewed this question
Top Icom Radio Communications Experts
peter0911
spencer hughey
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
