Question about Sport & Outdoor - Others
Where can get parts for my table ? I need the motor air
How do I manually raise a Zenith 440 Chiropractic table?
You must pick up on the tubes from the front. Pick up the tubes to raise the table as high as you can. You should be able to get it all the way up. You must then put something there to hold the tubes up. I use a long 2x4 when I am in the shop. When I am in the field working on one, I pick up the tubes and place an office chair over the front of the base and let the tubes rest on the top of the chair back. I use a standard chair not a roll around chair. The chair is safer than a board but it doesn't give you as much room to work. Let me know if you need more information or parts. You can get parts or get my number at www.chiropracticconsignment.com. Chiropractic Tables and Chiropractic Supplies
Jun 17, 2014 | Zenith Hi-Lo 440 Chiropractic Table
Bosch 4000 table saw motor does not turn, very stiff
Possibly something has jammed inside the motor housing although unlikely.
Electric brake seized perhaps?
Carbon brushes need replaced?
These saws (and the newer 4100) have a history of motor problems, with the field winding and electronic motor speed control being the most common points of failure. If you go to an online tool parts supplier like toolpartsdirect- Bosch 4000 saw you will see a list of the parts available, as well as the most commonly ordered parts.
Thanks go to Jason for his blog post at:
http://mypeculiarnature.blogspot.co.uk/2013/07/bosch-4000-table-saw-fix-momentum-lost.html
May 23, 2014 | Bosch 4000 - 07 Electric Table Saws
On a Craftsman 10" table saw Model 137.221960,
I have this saw. Motor just went on me (siezing up and smoking/burning) so if anyone can use parts then you're welcome to them. jmbombadil@yahoo.com in Conshohocken, PA.
Sep 20, 2011 | Craftsman 10" Table Saw
Hi, I need a replacement motor for my Bosche 4000. Have you got one? Thx Al Benting
I would start at the following site:
http://www.ereplacementparts.com/bosch-4000-0601476139-table-saw-parts-c-128_167_168.html
They don't have the complete motor but certainly have the parts needed to ge the motor back in operation. They have the brushes, the field and the commutator plus other items related to operation. I would also recommend reading some of their articles (like a forum) that gives problems and solutions.
Good luck.
Mar 16, 2011 | Bosch 4000 - 07 Electric Table Saws
Can ibuy complete motor
You can find your Craftsmen Table Saw on the internet at http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Saw-Parts?Type=Table saw.
Find your model number on your saw, and you should be able to locate the parts you need.
Feb 25, 2011 | Craftsman 10" Table Saw
Need electric motor for model #113241680. what is the rpm and horse power.
here is the sears parts for your saw
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113241680/0247/0744600?pathTaken=
looks like they dont sell the motor any more. as long as you have the spec plate on your motor you should be able to match up something from a parts house or anyone that sells electric motors. in my area its Granger
Dec 28, 2010 | Craftsman 10" Table Saw
Looking for cost of replacement motor for skilsaw model 3400 13amp for 10" table saw and where to buy from? Also, is there a 15amp replacement motor that would bolt right in to replace?
i looked online at places I get parts from. Neither listed the motor as a part the had the aramature for about $70 and the field for about $35. Have you tried the reset button? also it may just need new brushes.(if you see lots of sparks at the end of the motor opposite the blade, look through the air vent slots it is likely the brushes, unplug the saw, and take them out and replace them HERE is a blow up ) the I would think that if the saw is well used and the motor has burnt out. It may be a lost cause. I am not sure what the price of this was new but you can get a reconditioned saw from Amazon for 135 bucks. And it is a 15 amp saw.
Dec 07, 2010 | Skil 10" Table Saw 3400
Why does a table fan slow down after some time?
Revolving blades in table fans pushes out air towards the front by creating a vacuum at the back of the induction motor. Other than providing air flow, the gush of air also cools the motor. Over time, esp if used in a polluted surrounding, dust collects inside the motor and causes friction in the shaft. If left for a prolonged period, this friction causes heat eventually drying up the lubrication, causing breakdown in the motor amature windings and also a leaky starting capacitor, thus slowing down rotation and also a complete failure.
2. Fans must be regularly taken apart, cleaned and lubricated. It is fairly easy if you are willing to learn. My India made Usha brand table fan is 48 years old and is still running smooth - just changed the start capacitor last year and my National ceiling fans are more than 35 years old.
3. In fact all moving parts in any equipment must be periodically taken apart, cleaned free of dust and grime and freshly lubricated. It will outrun your lifetime and serve the next few generations.
Best Regards,
Mahathev of Malaysia
May 29, 2010 | Cfm 802 Ecofan Table
Motor seized
Check www.searspartsdirect.com to see if part is available.  Parts diagrams are also there so you can see how it needs to come apart to be repaired.
May 20, 2009 | Craftsman 10" Table Saw
Cant find parts for Harvard Air hockey table I need a scoreboard
Hi...
amazon is your solution. click here Amazon com Harvard Air hockey and chose your part. If you can't find it, feel free to contact any vendor, and they will provide to you I hope.
enjoy and best of luck
Jan 02, 2009 | Harvard Ice War 7' Hockey Game Table
Sport & Outdoor - Others Logo
725 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
