What is the tonnage of a carrier furnace model number 58gp100-2
Want to take out and install a split system
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 22 Answers
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Posted on Oct 11, 2015
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
RETAIL PRICE FOR ONIX REVERSE CYCLE SPLIT SYSTEM
contact shops that install units and get quotes. retailers generally have contractors that will give quotes for installation on new units.
Jan 01, 2015 | Heating & Cooling
Hello We just installed a Sanyo KHS1271 mini-split
The condensate drain line was not properly installed. Make them pull the wall unit and correct the problem.
Be persistant until you are satisfied they have the problem corrected. Do not pay any additional money. If they do not correct the problem then report them online to the state board of heating and air. Fill out their requested complaint form and follow thru with a second complaint if you do not get total satisfaction from the contractor that installed the unit.
Hope this helps.
Sep 23, 2011 | Sanyo Split System Air Conditioner
I am trying to figure out what tonnage this condenser is
The model number on the condensor tells you. Its always divisable by 6. So the number will be towards the end of your model number and be 6, 12, 18, 24, 30, 36, 42, 48, 60, or 72. Split system condensors stop at 5 tons or 72. If this doesn't help repost with the model number and I can easily tell you.
May 16, 2011 | Heating & Cooling
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
Need to know the tonnage ofCarrier s/s Model #38ARZ008, ser # 1404G20031
Brand: CARRIER Manufacturer: CARRIER CORP SYRACUSE Model Number: 38ARZ008(5/6)0 Condenser Type: air-cooled Coil Model Number: 40RM-008--B5/6GC System Configuration: Split System Air Conditioner Energy Efficiency: 10.6 EER Cooling Capacity: 90,000 BTUs / hour ARI Type Code: RCU-A-CB Electrical Service: Triple-phase Electrical Input: 8,490 watts per hour Voltage: 230 and 208 and 460
12000 btu's per Ton, equals to 7.5 Tons.
Sep 29, 2010 | Carrier 38CKC042 Air Conditioner
Installed LG split system. The unit does not
Any chance that you've got L1 and L2 hooked up to the same leg of the main? That would still give you 120 on each but not 240 from L1 to L2 like it should be. I'm not familiar with the LG system, but I would think that a comm line would have two wires.
Jul 14, 2010 | LG Art Cool LA181CNW Split System Air...
Heating & Cooling Logo
481 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
