Question about Panasonic Audio Players & Recorders
My panasonic SA VK800 cant turn off the demo fitur after i turn off power for stanby,help me please... ??????????????..
5 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Fault code
speaker cord connector problem:-
remove all speaker connectors and insert it one by one each time until you find the bad one and change its connector with a new one.
(you must play something and listen).if all above does not work you will have problem in power supply and need to fix.
Posted on Apr 04, 2008
  • 4 Answers
SOURCE: sa-ht740 power problem
is power supply connected to us or euro power.
the power in europe is 50herz us is 60 herz this
could pose a problem or the polelarity could be
cross
Posted on Feb 13, 2009
SOURCE: my panasonic sa ht7o plays dvds fine but no
you have it hooked up as a component with one of the three video cables crossed
Posted on Aug 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: my dvd stereo system panasonic model SA DK2 , F61
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Posted on Feb 21, 2011
Panasonic sa-vk800 when the volume up the unit is shoot down than display f16
Check all of your speaker wire connections at both ends for looseness, strand wire fraying/breakage, correct polarity and corrosion. If all are ok, reduce your setting for the amount of bass it outputs.
Dec 15, 2014 | Panasonic Sa-ht70 Home Theater Receiver 5...
Standby led but cant on power
Look like malfunction AMP PCB Board.Please open top cover, unplug flex cable attached to connector AMP PCB. Try now power- ON the unit.
Jul 24, 2014 | Panasonic Home Theater System System
Got a Panasonic CD stereo system SA-AK410 When I turn it off after a few seconds it turns back on. Is this normal?
That's because you haven't set the clock on the system. I jumps to DEMO mode once you turn it off without the clock set. Clock can be set through your remote. Hope this helps. Cheers.
Oct 04, 2013 | Panasonic Remote Control Eur7710020...
I have a panasonic cd stereo system model number sa-ak29 every time that I turn it off 1 second later it come back on.
your system isn't turning back on it is a demo screen. find the button that says something about a demo and press it while the system is off. if that doesnt work press and hold the button while the system is off. if that doesn't work refer to your manual on how to shut off the demo
Jan 05, 2011 | Car Audio & Video
Dont know how to stop the demo mode. Panasonic SA-AK630 stereo
Set the time via the remote control and this will stop the demo running every time you turn it off.
Jun 14, 2009 | Panasonic SC-AK630 CD Shelf System
My cd stereo system sa-ak630 wont come of demo mode what do i do
there is a button on the left side that says "-demo" on it. hold that button until it stops...
Jun 05, 2009 | Panasonic SC-AK630 CD Shelf System
SA AK200 does not appear to turn off completely
HiFi system actually turned Off when you press power button and display of hello, heavy, vocal etc is demo mode of this system and it activates when unit goes to power off.
You can change its settings like not to show demo mode etc and this procedure is described in owner's manual.
Thank you.
Dec 15, 2008 | Panasonic SC-AK200 CD Shelf System
Panasonic sa ht 540 fault 61
my panasonic sa ht540 starts up and then says f61 then goes to stanby
Apr 18, 2008 | Televison & Video
Wont come out of stanby mode ??
The trouble your describing tells me that theres a short in the output circuit of this unit. Unless you know how to troubleshoot solid state electronics, Please take to a pro to have it serviced , as there are no user serviceable parts inside this unit. Good Luck
Jul 24, 2006 | Panasonic SA-XR50S 6.1 Channels Receiver
48 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
