Question about Dometic RM2652 Refrigerator
REFER HAS A 385041501 AND THE LEFT RELAY FLICKERS ON AND OFF WOULD THS BE THE 120 VOLT HEATER OR THE CONTROL PANEL. THIS ALSO CAUSES THE AUTO SWITCH LITE ON THE UPPER PANEL TO FLICKER ALSO
    Habit-Forming:
  • 20 Answers
Could be a number of different things.. Start by making sure you have at least 12v on the battery supply.(they act weird when voltage is low). If the voltage is good then disconnect the 12v and unplug the 110v(or you'll get shocked) and go through each connection and disconnect and spray electric parts cleaner on both ends, dry them(compressed air) and re-connect them make sure all the connections fit snug. And pay special attention to ground wires, they tend to be most problematic. Plug it back in and if you still have the problem i would say the circuit board(lower one referenced) is most likely going out and should be replaced. Usually just the relays go bad on the boards...but sometimes other parts do to.
Posted on Jul 11, 2015
Where is the signal light relay that makes signal lights flash located on 2000 ols intrigue 3.5 liter
Important: The hazard warning switch includes the turn signal and hazard warning flashers.
Removal Procedure
Remove the center air deflector. Refer to Instrument Panel Center Air Outlet Deflector Replacement .
Squeeze the retainer on the backside of hazard warning and cruise control switch.
Pull the hazard warning and cruise control switch from the retainer in the instrument panel.
Disconnect the electrical connectors from the hazard warning and cruise control switch.
Remove the hazard warning and cruise control switch from instrument panel.
Remove the hazard warning and cruise control switch bezel from the instrument panel trim pad by using a small flat-bladed tool to the release retainers.
Remove the radio. Refer to Radio Replacement in Entertainment.
Reach through the radio opening and push the retainers up towards the roof of the vehicle. When the retainers release, slide the instrument panel (I/P) center air outlet deflector out of the I/P opening
Remove the air outlet deflector
Remove the instrument panel accessory trim plate. Refer to Instrument Panel Accessory Trim Plate Replacement in Instrument Panel, Gauges, and Console.
Remove the bolts from the radio.
Pull the radio toward you.
Remove the front floor console trim plate. Refer to Front Floor Console Trim Plate Replacement .
Pull the instrument panel (IP) accessory trim plate away from the IP trim pad.
Disconnect the IP harness seat heater leads, if equipped.
Remove the seat heater switches from the IP accessory trim plate, if equipped.
Remove the IP accessory trim plate.
Nov 09, 2016 | Cars & Trucks
Y need book for fuse box
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat,
i copied this off another post hope this helps
Oct 09, 2016 | 2003 Ford Explorer
Heil model NUGI125DH03 heater fan doesnt shut off when after burners are extinguished and plenum is cooled. Is it Limit switch or control relay
Confirm that the FAN (auto/on) switch at the thermostat is in the auto position.
I have cycled between the auto-on positions on the thermostat and confirmed that the control relay is sticky. After a few cycles the control relay sticking had corrected itself. I attribute it to residue on the contacts collecting and after a few cycles cleans off.
The limit switch has also failed but can be easily checked by checking the control voltage, Remember that the limit control has two circuits one is 115 volts the other is 24 volt control circuit.
The other circuit for cooling can also activate the fan control relay depending on the control logic set up. So the thermostat has the ability to activate the fan either by the (auto/on) or cool cycle if an A/C unit is attached to the furnace.
I would not assume that it can only be the limit or control relay. Less likely a shorted wire or defective thermostat could cause the same result.
Nov 30, 2015 | Heating & Cooling
Where are the fuse boxes located in the jayco freedom pop top, 2000 model please, we have searched and are unable to locate it
If it's the 120 volt panel you're looking for, follow the power cord into the unit. If it's the 12 volt side, these should be near or behind the 120 v panel.
However, that's not always the case with Jayco. Often the power cord comes in at the rear and the panel is in the middle of the unit. In some models it's in back of the plywood panel under the refer.
Some appliances (such as a refer) have their own fuse located on the control panel.
If you contact Jayco they will send by email the owners manual for your model and year. Here's where to contact them at:
Contact Customer Service Jayco Inc
Jan 03, 2015 | Cars & Trucks
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Jul 20, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
catalytic converter
valve,
change-over valve,
solenoid valve 1,
Fuel metering valve
solenoid valve 1
Fuel pump relay
Brake light switch
wipe relay (AW1)
Fuse 1 - Not used
Fuse 4 - Not used
Fuse 5 - Not used
Tail lights
Fuse 11 - Not used
Fuse 12 - Not used
Air quality sensor,
28-pin connector
ABS control module,
Light switch,
Fuse 17 - Not used
Tiptronic switch,
Fuse 21 - Not used
Converter box,
Alarm horn,
Alarm horn relay,
Light switch,
Fuse 27 - Not used
12 V socket,
12 V socket 2,
Blocking diode
A/C control module,
Fuel pump relay,
Fuel primer relay
A/C control module
Fuse 56 - Not used
Hope this helps
--N
May 31, 2014 | 2010 Volkswagen Jetta
Abs fuse
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump2.gif relay and RAP module
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
36=7.5A CD, rear integrated control panel, memory seat, Message center Attached images fuse%20box001.jpg?imgmax=800 __________________
Oct 29, 2009 | 2003 Ford Explorer
I need a fuse box diagram for a 2003 Ford Explorer Sport
I believe that this is what you are looking for.....
Fuse and relay locations--2nd generation power distribution box Layout- I think this is a good sticky candidate--
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
Oct 10, 2009 | 2003 Ford Explorer Sport
Need switch fort Presto Quartz Heater
Hello
Any hardware store should have a replacement switch for you. Let me break the numbers down to help you out.
INF = Infinite switch
120 = 120 volts
887B = model number of the switch
34-191 = date code
15 amp = ampacity rating of the switch
120 vac = Again this is a 120 volt switch A/C
If you need anymore assistence please comment back.
May 06, 2008 | Heating & Cooling
Dometic RM2652 Refrigerator Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
