Question about Frigidaire Gallery FGHD2465NF Fully Integrated Dishwasher with 14-Place Settings, 7 Wash Cycles, 5 Wash Levels, NSF Certified, OrbitClean Spray Arm, Soft Food Disposer and 53 dBA: Stainless Steel
What do I adjust to prevent the door from opening too fast? When I open the dishwasher door I must hold it so it does not come down too fast
  • Frigidaire Master
  • 932 Answers
Herbert,
You probably have a broken door spring or a hing cable. I looked your model up on Sears parts direct and have included a link. You are looking for item #1 or #1A. Good luck! http www searspartsdirect com frigidaire dishwasher parts model...
Posted on Apr 08, 2015
Why does the door pops open when starting
I would check how level the dishwasher is. Might need to adjust the feet.
Aug 14, 2014 | Meiko FV 40.2 Dishwasher
We have a 301HT and the door is not staying at the 90 degree angle it should hold at. The door is coming too far down and putting additional pressure on the bolts inside. How can we fix this?
The manual will show a bushing under the adjusting nut at door frame opening that holds the door from dropping too far. This bushing usually breaks and disintegrates. Bushing is just over 1" long. Check both bushings on each side of door opening of machine.
Aug 21, 2013 | Moyer Diebel 24 in. 301HT-40 Built-in...
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
Feb 27, 2013 | Whirlpool Gold GU2275XTV Builtin...
Door wont close
open the door now look to see if the screws holding the dishwasher in place have worked loose and are hanging down preventing the door to close. On the underside of the counter top
Mar 12, 2011 | Dishwashers
Dishwasher leaks water as it fills
  • Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  • Step 2 Open the door completely and remove the bottom dish rack.
  • Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  • Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  • Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  • Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
    Fixing a leaking door
  • Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  • Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  • Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  • Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  • Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
  • May 14, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
    My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
    I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
    Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
    Apr 17, 2009 | Dishwashers
    The door to my dishwasher swings open to fast
    You will need to bring the DW about 8-10 inches out from under the counter to access the door springs on the side of the unit.
    Any questions, let me know
    Please take the time to give this solution a fix ya rating
    clarkco
    Feb 27, 2009 | KitchenAid 24 in. KUDI01FL - Multiple...
    Kitchenaid dishwasher door does not stay up in the open position.
    On each side of the dishwasher, near the ground, is a nylon cord and pulley apparatus that keeps the door from flopping down when opened. It probably needs some adjustment of the tension on the cord.
    Feb 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
    Adjusting the door on a neff dishwasher
    I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
    Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
    GE Monogram DIshwasher
    Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
    Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
    Frigidaire Gallery FGHD2465NF Fully Integrated Dishwasher with 14-Place Settings, 7 Wash Cycles, 5 Wash Levels, NSF Certified, OrbitClean Spray Arm, Soft Food Disposer and 53 dBA: Stainless Steel Logo
    122 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Robert Roath
    Robert Roath
    Level 1 Expert
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
