#BESBY-1500 Electric Stove Heater How can I replace the TOP it is made of plastic
I accidentally doped it when i was moving it from my grandmothers to my house
  • 1073 Answers
SOURCE: I have a smooth top
NO THE CRACK COULD HAVE RAN THROUGH THE TOP AND ELCTRICUT YOU
Posted on Apr 29, 2008
  • 161 Answers
SOURCE: Electric stove top
Follow the wire, It should go to a junction box within 4 feet. It may be behind a cabinet. Remove the box cover and unscrew the wire nuts. It usually uses armored wire and this is clamped to the box. Release the clamp . Turn off breaker or remove the 2 fuses first.
Posted on Jul 01, 2008
huuum
  • 750 Answers
SOURCE: electric stove top and oven
Welcome to fixya.
Range does not heat (lights and timer do not operate).
This would indicate the range is not receiving the required 220 volts. Check house hold breakers or fuses, open wiring between the terminal block and the components, and the power cord.
Please remember to leave a rating before you leave
Posted on Dec 10, 2008
memturbo
  • 226 Answers
SOURCE: Can you replace electric eyes with glass top?
there is more to it than just replacing the glass .
and I'm not aware of any kits that allow this .
Posted on Mar 27, 2009
localwonder
  • 6784 Answers
SOURCE: stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Posted on Apr 02, 2009
Why are lights not working under the ceramic JennAir stove top?
You have probably accidentally disconnected some wiring whilst moving it need to re explore
Apr 27, 2014 | Jenn-Air JED8430 Electric Cooktop
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I replace or repair the flame effect?
Typically the flame effect is accomplished when a motor turns a rod with polished metal strips on it. The strips then reflect the light onto the back of the glass. The the rod rotates, the reflection moves giving the effect of the flames moving. If the lights work on your unit then the motor has most likely stopped. It would need to be replaced. A quick internet search turned up nothing for that company so you may need to go back to the store where you purchased the unit to get the part. Once you have the part, you will need to disassemble the unit. Some units are simple (like removing the fake logs) and some units are more involved (like removing access panels from the back or bottom).
Mar 10, 2014 | Vendor Development Group Inc Borgen...
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I get a replacement flame effect?
I have water leaking from the bottom of my waterheater PE50T9A
It is possible that the water heater has a leak at the bottom. They eventually rust out. The valve should be removed if it is leaking and you should replace it. They are cheap. Be sure to use teflon tape to seal it back up
Apr 27, 2009 | Water Heaters
Damage to the bottom of Cuisinart cordless tea pot mod KUA-17
Even though there are no parts listed at the cuisinart.com website, the company does a few base pieces left in stock if you call them directly - 1-800-726-0190
Apr 11, 2009 | Cuisinart KUA-17 Cordless Electric Kettle
Flexible copper water heater with washer leaks at cold inlet .
pipe dope not needed tighten snug then one quarter turn is recommended by most mfg
Dec 18, 2008 | Watts Copper Corrugated Water Heater...
Water heater leaks on top
Make sure to use pipe dope(compound) or teflon tape on the threads. If you use the tape make sure to wrap the tape in the direction of the threads. Don't over do it with the tape 5 or 6 wraps should be fine. I prefer pipe dope myself....Joe
Dec 16, 2008 | Water Heaters
Replacing smooth top
You said, you broke the top of my stove - how do i go about replacing it? I have a maytag smooth top stove I don't have the model number its torn off the stove was here when I moved in and now its broken and has a big crack in it how do I get a replacement please help.
This is more than likely your ranges model # MER6772 Gemini Electric Kitchen Range
Maytag will be able to replace the top once they come out!
Below is the info and help you asked for!
Thank You , Huuum
Please remember to leave a solved rating before you leave!!
Here is what you asked for!
Call the dealer from whom your appliance was purchased or call Maytag Appliances
Sales Company, Maytag Customer Assistance at 1-888-462-9824, USA to locate
an authorized servicer.
Be sure to retain proof of purchase to verify warranty status. Refer to WARRANTY
for further information on owner’s responsibilities for warranty service.
If the dealer or service company cannot resolve the problem, write to Maytag
Appliances Sales Company, Attn: CAIR® Center, P.O. Box 2370, Cleveland, TN
37320-2370, or call 1-888-4Maytag for PriorityOne Service (1-888-462-9824).
U.S. customers using TTY for deaf, hearing impaired or speech impaired, call
1-800-688-2080.
NOTE: When writing
Oct 14, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
