Question about Cooking
How do I moisten so that it is not so dry
The tobacco is dry
    Problem Solver:
  • 14 Answers
When I have problem I will put a damp paper towel in a sandwich baggy and leave the bag open and place the baggy in my contain full of tobacco.
Posted on Oct 12, 2015
The injector shaft will not push the tobacco into the tube, it seems to be jammed, how can I fix this?
Make sure your tobacco doesn't have too much moisture in it to start with then try using less tobacco. Too much tobacco will cause the plunger to halt when it is only partially deployed.
Dec 07, 2016 | Cooking
What were steps taken by the Health & Family Welfare Minister to prohibit tobacco sales in Chhattisgarh?
The Chhattisgarh government is planning to prohibition on the offer of tobacco in the state. Wellbeing and Family Welfare Minister Chhattisgarh Ajay Chandrakar guided senior office authorities to set up an activity get ready for restricting offer of tobacco, an administration official said here. The state government has officially banned tobacco-based gutkha and skillet masala items and is presently thinking about to totally boycott tobacco. Ajay Chandrakar said that, keeping in view the general population enthusiasm, there should be a genuine thinking on banning tobacco-based items in the state.
Nov 08, 2016 | Computers & Internet
WHAT'S THE DIFFERENCE BETWEEN ELECTRONIC CIGARETTES AND TRADITIONAL TOBACCO CIGARETTES?
The most common difference between e-cigarette and traditional cigarette is that e-cigarette do not contain tobacco. Tobacco is the main ingredient in a cigarette, which cause Cancer. Traditional cigarette contains lots of harmful chemicals.
The body's reaction to many of the chemicals in traditional cigarette smoke causes long-lasting inflammation, which in turn leads to chronic diseases like bronchitis, emphysema, and heart disease.
E cigarettes are completely different. They use liquefied nicotine and produce less-harmful water vapor instead of harmful smoke.
E cigarette comes with various flavors. It contains e-liquid, which adds flavor to it. You can refer Shake N vape for more details.
Nov 24, 2015 | Computers & Internet
How do I moisten it so it is not dry
Depending on how much tobacco you want to re-hydrate, get a terra-cotta pot and break it into pieces and soak a piece (or several pieces) in distilled water. Put the soaked chunk(s) in a plastic zip-lock type bag with your tobacco. Leave it overnight and check the tobacco for moistness.
Be sure to use distilled water and a new pot to start. It might be a good idea to boil the terra-cotta in water for ten minutes or so in order to kill bacteria. Using tap water can introduce bacteria and chemicals (chlorine) into your tobacco. You do not want that.
The terra-cotta will prevent soaking your tobacco with too much water and causing mold.
Apr 07, 2015 | Cooking
Jam up
Use a small screwdriver and insert it in the tabbaco outlet to get the tabbaco out. be care full not to overstuff when filling.If you get a lot of jams the tabbaco can be to moist. if so let it dry out a little before inserting. Also the bottom of the bag 'shake' will jam the machine.A nice tabbaco that is very easy on any machine is a virginia blend.
Feb 17, 2014 | Powermatic 2 Electric Cigarette Injector...
Tube will not fill near filter
Trick i have learned is to put a small amount of tobbaco in the chamber now move it side to side with your finger tips. Now add more tobbaco to the chamber as you normaly would.It will fill the tube better If that does not work out for you try virginia blend tobbaco it will work better in any machine...
Jan 15, 2014 | Powermatic 2 Electric Cigarette Injector...
What is tobacco?
Tobacco is a plant whose brown-colored leaves are cured, dried and rolled into every cigarette. You can smoke tobacco in cigars, cigarettes or a pipe. You can also chew tobacco or snort it as snuff.
Feb 06, 2013 | Cooking
Top o matic cigarette injector is only filling the cig half way
Hi Mindy,
Make sure that your tobacco is not too wet. Set some tobacco out (about the amount you plan to roll) and let it air dry for about 5 - 15 minutes. You'll have to figure out how long to let it dry as your home temperature is different than mine. Don't let it dry too much though. Give this a try. It works for me.
Take care,
Dennis Mason
Jun 17, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Printer Problems-Hp Deskjet F380
It isn't really 'printing' a white line but rather NOT printing at all. These are generally called 'voids' in the copier trade.
About the only thing that can cause this is the momentary loss of contact of a 'common' electrical pathway.
Removing the the cartridge, you will find a pattern of contacts, normally on the back of the cartridge.
Try using a cotton swab moistened (not dripping) with rubbing alcohol to scrub the contacts and reinstall after it is dry again. You can safely wipe any remaining moisture away with another swab.
If the loss of contact is caused by any contaminents, this is enough to remove them.
Avoid touching the nozzle area to prevent other problems.
This may not apply to you but this kind of problem can be caused by tobacco smoke which produces a sticky film often causing electrical problems in paths handling low currents.
May 12, 2008 | HP DeskJet F380 All-In-One Printer
Cooking Logo
155 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Are you a Cooking Expert? Answer questions, earn points and help others
