Question about Imperial IFS40 Deep Fryer
Imperial ifs40 fryer suiting up.
Was supposed to have been converted to LP. Can someone tell me what the hole diameter of the burner orifice should be? Or could it be that a single 20lb propane is used as the supply?
  • 24 Answers
If you don't know that you are doing you should buy them. You need one for each burner, 3 or 4 for most models. Yes they can be drilled out going only one way, using lettered drill bits that are hard to find. The regulator on the back normally has to be adjusted also. If either is wrong, the flame will be to big or to small to heat correctly. At least buy one orifice and check the size hole, they are not expensive $5 -$10 if you do a little searching for a good price.
The Part Numbers are:
Orifice - NAT. Gas 1625-36
Orifice - L.P. Gas 1625-51
You MUST use Lettered drill bits for size, Like A-Z If it was drilled with any normal size bits 1/16 type bits it will NOT be correct! There should be a number stamped on the orifice, unless it was drilled out. Most people never mark the door that the gas type was changed, causes all types of problems for the service men.
Can you give more details to your problems? I couldn't find the hole sizes right off, but have seen it listed.
Posted on Apr 07, 2015
  • Michael Janssens
    Michael Janssens Apr 08, 2015
    The fryer was supposed to have been converted to LP. There is no marking on the burner orifice. The hole is between 3/64 and 1/16. If it is the correct size then I will look elswere for the problem.
  • Michael Janssens
    Michael Janssens Apr 09, 2015
    I got around to the burners today, the holes were in pretty bad shape, a lot of plugged ones. Ran a drill bit into them by hand and got a ton of rust out. Hopefully that is the problem. Will connect fryer to propane this weekend and test it.
On my ifs40 imperial fryer the pilot knob just spins around and wont send gas up to pilot orifice when i push it in
There is a little tab on the knob that is broken. Replace the knob and the fryer will work. One center screw holds the knob on the valve.
Jul 19, 2016 | Imperial IFS40 Deep Fryer
Cecilware fms40 fryer convert to lp gas
Most NatGas devices will convert to use of LP by changing the orifice.
GRINDMASTER CECILWARE F177A ORIFICE 52 1 16 LP GAS
Oct 05, 2015 | Cecilware FMS-40 Deep Fryer
From natural gas to propane
Page 3 shows your conversion kit part numbers provided by PARTSTOWN
The pilot light has to be converted to LP. The burner orifices must be swapped out and the gas valve must be converted. from Nat to LP. Do your swap out and open your air shutters. Light it off and tweak the air as needed then party on!
Jul 26, 2011 | Imperial IFS40 Deep Fryer
Yes have an imperial elite efp-40 and its natural gas but we are switching it to propane and they sent us a piece with no instruction and says goes in under the on off pilot know but when we took off there...
Due to differences between natural gas and propane, they require differing amounts of gas supplied to the burner. This is controlled by the size of the opening where the gas goes into the burner. The mechanism for control is called an "ORIFICE," which usually is made of brass, and looks like a short, fat bolt, with a tiny hole at the center of the bolt head. The difference between the orifices for each gas is accomplished simply by varying the size of that hole.
There is a conversion kit that you can buy at the hardware store. It is fairly simple to do.
Typically it involves switching out orifices, which look like a short bolt with a hole in the middle. Take out the old, put in the new.
Jul 23, 2011 | Imperial IFS40 Deep Fryer
I JUST BROUGHT THIS IMPERIAL DEEP FRYER AND I WANT TO CHANGE FROM NATURAL GAS TO PROPANE GAS.
You will need a conversion kit from natural gas, most of this kit contains gas valve spring, burner and pilot orifice. Check the nearest authorized dealer in your area and ask buy the appropriate conversion for your fryer.
May 28, 2011 | Imperial IFS40 Deep Fryer
Imperial ifs 40: gas comes out of jet and the burners work fine for a moment, then the flame ignites inside the burner and makes a worbling noise every now and then popping. is this low gas...
Check your manual and make sure your burner is configured for the gas that you are using. In most cases, there is an orifice that needs to be changed for using LP, or a screw setting that needs to be changed- most new appliances ship with a "city gas" configuration ( AKA NG - Natural Gas) and need to be configured for LPG (Liquified Propane Gas). The fitting(s) that need to be changed are tagged. This is due to the pressure difference between NG and LPG. Propane (LPG) runs at a higher pressure.
You state that your fryer is LPG. If you are running it on NG ("city gas") you need to consult your manual for converting it to NG. Outside of making sure that you are set up for the right gas, you should not have to make any other adjustments. For safety reasons, gas regulator pressure adjustments are for the most part no longer possible on gas appliances.
Mar 21, 2011 | Imperial IFS40 Deep Fryer
WE HAVE A NUMBER OF LPG IMPERIAL IFS40 FRYERS WITH A VERY LARGE FLAME ESSESIVE FOR THE UNIT FLAMES BURNS AND EXTENDS AT THE BACK OF THE FRYER INTO THE FLUE . WE HAVE CHECKED THE CORRECT INJECTOR , CORRECT...
check the burner orifice and gas valve spring kit if it is suited for propane use.remove carbon build up inside the fire tubes.check also if the gas pressure is correct.
Mar 11, 2011 | Imperial IFS40 Deep Fryer
Soot build up
Flame is Orange? If so, propane is "choked", not enough air. Remove burners, clean each burner hole with a same size metal dowel (coat hanger works well) flush out inside of burner with garden hose, hi pressure air through all holes to dry. Replace burners ONLY after also cleaning chambers and chimney (garden hose and long brush). Do not forget to clean pilot light area too.
Most Imperials are pre-set air intake. Check gas pressure if able, 3" NG, 10" LPG. Good Luck
May 12, 2010 | Imperial IFS40 Deep Fryer
Change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
227 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
