Question about Cooking
How do I moisten it so it is not dry - Cooking
    Habit-Forming:
  • 54 Answers
Depending on how much tobacco you want to re-hydrate, get a terra-cotta pot and break it into pieces and soak a piece (or several pieces) in distilled water. Put the soaked chunk(s) in a plastic zip-lock type bag with your tobacco. Leave it overnight and check the tobacco for moistness.
Be sure to use distilled water and a new pot to start. It might be a good idea to boil the terra-cotta in water for ten minutes or so in order to kill bacteria. Using tap water can introduce bacteria and chemicals (chlorine) into your tobacco. You do not want that.
The terra-cotta will prevent soaking your tobacco with too much water and causing mold.
how do I moisten it so it is not dry - 25633907-2pfur4mk4dxywo0p1vdxsymj-3-0.jpg
Posted on Feb 01, 2016
How do I moisten so that it is not so dry
When I have problem I will put a damp paper towel in a sandwich baggy and leave the bag open and place the baggy in my contain full of tobacco.
Apr 07, 2015 | Cooking
How to clean the sticky rubberisth remote nothinbg was spilled on remote it is just sticky...has a rubber back
Rubbing alcohol and alcohol and a few cotton balls.
step 1.)
With a alcohol moistened cotton ball (not too much alcohol)
clean the back of the remote.
step 2.)
Dry remote off, with a dry cotton ball
step 3.)
Enjoy your new non-sticky remote control :-)
Sep 24, 2011 | Dell C6129 Remote Control
If the Play Doh has been left out and become dry, how can I rehydrate it? Can I seal it in its container with a moist piece of cloth, or add some type of oil?
try the official play doh site
http://www.hasbro.com/playdoh/
Even if the tip does work for you ... check out the site anyway they have tons of out to make items with playdoh
This is the tip they give you to re hydrate your playdoh
My PLAY-DOH compound is drying out. How can PLAY-DOH compound be softened or moistened?
To restore the softness to PLAY-DOH compound, try adding water one drop at a time and working it in to moisten the PLAY-DOH compound.
You can also try wrapping the PLAY-DOH compound in a damp paper towel, returning it to the container and replacing the cover. Let it sit overnight
Good Luck. RJ
May 09, 2011 | Play Doh Toys
How to clean sunbeam ultra 60 platinum iron. Can't find instruction booklet!!!!!
Do you mean the Sunbeam Ultura 60 Platinum iron? Wipe the exterior of the iron with a damp soft cloth and then dry the iron. To clean the steam valve, turn the Steam/Dry dial to Clean so that the tip pops up. Gently scrub the tip of the valve with a steel wool pad moistened with warm water. Rinse and dry with a soft cloth. Replace the valve and turn clockwise to lock into place (reset the dial to Dry when storing the iron). Clean the steam holes of any build up, use a cotton wool tip moistened with methylated spirits. The teflon plate should be cleaned with the damp soft cloth, just like the rest of the exterior of the iron. If you have ironed a polyester that melted onto the iron, then iron a damp cotton cloth when the iron is hot.
The manual for several Ultura irons, including the 60, is available here: http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1485 . The link for the manual is in the center of the page above the Image Gallery.
I hope this helps.
Mar 06, 2011 | Sunbeam Vacuums
Printing is blurry and streaked. both new cartridges installed
You may need to remove the ink cartridge, both, and with a soft cloth clean seat print head. It works better if moisten cloth. Finish with a dry cloth.
Oct 26, 2010 | Canon PIXMA iP6220D InkJet Photo Printer
Only prints half way and doesn't grab paper right away
Here are the steps:
1.Remove the power cable from the printer.
2.Remove the paper tray from the printer and leave the
paper tray door open.
3.Lightly moisten a lint-free cloth with water.
4.Use the moistened cloth to gently wipe clean the surface
of the roller.
5.Let the feed roller dry before plugging back the AC
power cord
6. Fan the paper to keep the sheets from sticking
together.
7.Place 15 - 20 sheets of paper into the paper tray
8.Insert the paper tray into the printer.
9. Make a print.
If issue persists, call 1.800.235.6325 for repair.
Sep 24, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Cleaned heads about 10 times. Still get no magenta and a light black Also replaced magenta cartridge
Remove the cartridge from the printer. Wipe the cartridge electrical contacts and the corresponding carrier contacts with a dry fabric or paper towel. Then moisten a paper towel and wipe the cartridge printing surface (not the electrical contacts) until clean. Also you can hold the moist paper towel against the cartridge printing surface for a couple of minutes to dissolve dried ink. As a last resort, I have immersed cartridges in water to dissolve the dried ink. Dry all cartridge surfaces with a dry paper towel then reinstall into the printer carrier. Good luck.
Aug 22, 2009 | Office Equipment & Supplies
Disc Skips
The non-technical answer would be that the lens needs to be cleaned. This is the first step for this type of problem. There are many things that can get the disk drive lens dirty like smoke, incense, dust, moisture. Open the unit and open the DVD cover. You will see the lens that reads a DVD. Get a cotton swab (the ones for cleaning out ears) and some isopropyl alcohol (rubbing alcohol) and moisten the cotton swab with the alcohol (moisten not soak) and gently (I mean, do not push hard or scrub hard) rub it on the lens. Now with a dry cotton swab, do the same. Let it dry for a minute (longer if the swab had more alcohol and it might have dripped down) and close the unit. Now try to play DVDs and let us know if it worked. Thanks.
Jun 19, 2008 | Cyberhome CH-DVD 300 DVD Player
Not playing dvds? samsung dvd_r 130
Jun 18, 2008 | Televison & Video
I have an MP460 printer. Suddenly it won't print. When I try to print a document from Word, the printer acts like it's printing--goes through the motions, spits out a page, but nothing is on that page,...
  1. Open the front cover of the printer and remove both cartridges.
  2. Moisten a clean, lint-free cloth with water and gently wipe the gold nozzle area.
    Warning!
    Wipe the nozzles of the color cartridge in one direction so the colors do not mix.
  3. To dissolve dried ink, hold the damp cloth against the nozzles for about three seconds. Gently blot and wipe dry.
  4. Moisten another section of clean, lint-free cloth and gently wipe the gold contact area.
    Warning!
    Do not wipe the nozzles and contacts with the same section of cloth.
  5. To dissolve dried ink, hold the damp cloth against the nozzles for about three seconds. Gently blot and wipe dry. Let the gold-colored areas dry before you reinsert the cartridge into the printer.
  6. Reinsert the cartridge and repeat the nozzles test.
May 17, 2008 | Canon Office Equipment & Supplies
Cooking Logo
125 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Are you a Cooking Expert? Answer questions, earn points and help others
