Question about Hilti Drills
Reset hilti te70
I how reset hilti TE70
2 Suggested Answers
  • 123 Answers
SOURCE: te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Posted on Jul 23, 2010
Is there annybody in the netherlands with a service reset tool SRT from HILTI?
Mogelijk is er voor de powertool een hack the vinden door hilti service reset tool op google of YOUTUBE in de zoekmachine in te vullen voor mogelijk enkele corresponderende voorbeelden tja marketing technische truukjes te veel Hilty is op zich niks mis mee mogelijk is de overstap op DUSS powertools voor de toekomst een betere optie
Aug 23, 2017 | Hilti Drills
What type of oil to be used in TE70 drill?
I assume you mean for the chuck. Hilton sells a very thick lithium based grease.
Jan 05, 2015 | Drills
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
My te70 doesnt wok and the red light is on
The service light usually comes on when the brushes are low. The brushes usually have a small metal tab that grounds out when the brushes wear down to the point of needing to be changed.
Aug 26, 2011 | Hilti TE 70 Hammer Drill Performance...
Te70 hilti hammer drill
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Red service light on ,have checked brushes and they are as new, won't operate at all
Hi. It all depends on the age of it as there are 2 different types of electronics fitted to the TE76.
If you have an early model, the service light came on when the brushes were worn or it was in need of a service. Check your brushes 1st. then to reset the light, simply pull the trigger and hold it untill it resets.
If you have the newer type then you will need to reset the service light by attaching a data reader to the service light. this data reader plugs in to a PC, you will also need the HILTI ODA Software to go with it. Basicaly you need to send it back to hilti to have is serviced and reset. if your machine is less than 2 years old, this is FREE. just phone hilti and ask them to collect it. they will pick it up, service it and get it back to you in 3 working days. if you not sure how old your machine is simply phone Hilti and ask them, quoting the serial number. this is etched into the plastic on the left side of the machine underneath the white writing on the motor housing. Good Luck
Sep 24, 2009 | Hilti Drills
I have a Hilti TE 905 AVR the service light came on and it stopped working. Is there a troubleshooting guide to fix and reset this. Also, schematics can be found at:...
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Jul 08, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Makin a pandora battery
its very simple... you first have to open up the case of the battery (BE CAREFUL) depending on what battery you have you have to cut a pin on the motherboard.. thats it. look for a chip called "TE70 593C56". also try typing "pandoras battery" in google images and then type in what type of battery you have after it. you should get a picture of what pin to cut, i lifted mine up with a bobby pin... be very careful, dont even touch the motherboard with it. NOTE this will not work with batteries not made by sony.
Apr 25, 2008 | Sony PlayStation Portable (PSP) Console
Drills Logo
223 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
