Turns on No display Lights flash 3 times - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 8,155 Answers
Is it making a beeping sound?
if so check ram.
check the fan is running,if not clean it out.
try and start with the battery out,some laptops will run with out battery,if it does replace battery.
if it still wont start please get back in touch.
Posted on Apr 10, 2015
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Tip
What to do if you have 3 flashing red lights on your Xbox 360 Console?
If you have the 3 rings of Death (3 Flashing Red Lights) on your xbox 360 console, all you need to do is to contact Xbox Support and report this issue with them. The Console has a 3 year warranty for the 3 flashing red lights. Just make sure you did the following first:
1. Power Cycle your Console (Turn it off, unplug the power adapter from the wall outlet, wait for 30 seconds, turn it back on)**This is the best solution and it usually works!!
2. If still persist, Turn it off, remove any accessories connected to it (Hard Drive, Controllers, etc.) turn it back on without those accessories. **These accessories sometimes causes the problem.
3. If removing these accessories removed the 3 flashing lights, attach the accessories one at a time, every time turning it off and attaching one and turning it back on checking each time if the red lights (any lights) appeared. It will tell you what is causing the error.
4. If all else fails, again CONTACT XBOX TECH SUPPORT on their Toll free number. Make sure that you tell the tech that you have done those things above so they can create a report for the issue. They love the 3 flashing red lights issue. I should know, I am formerly one of them. :)
on Jun 12, 2010 | Video Game Consoles & Games
W1213, pre-wash and main wash lights flash with the 3 lines --- fault code. I tried entering the service mode as I read online I should push and hold start, then turn on the machine, wait for the dot and...
You are in the service mode now. The buzzer LED displays a flashing rhythm of 2 flashes while the ROM ID is show in the display(this is what you are seeing), press the buzz button to advance to the fault register level. Here is the manual to the tech manual http://laundry.manualsonline.com/mdownloads/89c212d9-4843-4409-b17c-b3439c9b0d05.pdf
Dec 31, 2010 | Miele Touchtronic W1213 Front Load Washer
My xbox box has 3 red lights flashing... i know there are different types of error how do i know which on i have?
after turning it on, and seeing it display 3 red lights, hold the sync up button and tap eject.
The lights will change to a different pattern. This represents a number.
The number is four digits, so you'll have to hold sync and tap eject FOUR TIMES, remembering each pattern.
Pattern numbers are as follows:
4 red lights = 0
3 red lights = 3
2 red lights = 2
1 red lights = 1
Most common ones are 0020 and 0120.
Jul 17, 2009 | Microsoft Xbox 360 Console
When playing Xbox 360 Games i get Flashing lights/Lines
sounds like the graphics chip is on its way out might just be a cold solder joint normaly turns to 3 red lights when ppl mention this to me
Jun 08, 2009 | Sony Playstation 3 (PS3) Console
Lexus RX330 - "Maintence Required Light" flashes 7 times?
reset: turn ignition on...push odometer button till it displays mileage on car...not trip milage but actual mileage. Turn car off. Open driver's door, press and hold odometer button....turn ignition to on....hold odometer button for 10 seconds....odometer display will show -----,----,---,--,-,0000000....maintenance lights are reset...lights will come on every 7500 miles to remind you to change oil and check fluids etec....
May 15, 2009 | 2005 Lexus RX330
Error 22
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Jan 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
3 flashing lights
3 Red Lights Flashing - is a general hardware failure
  • Unplug everything and let it sit for 20 min. Re-connect and try re-starting
  • If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  • Check the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the console flash red.
For more things to try check here
Nov 23, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
David Payne
David Payne
