Question about Whirlpool 27 Top-Load Coin Operated Commercial Washer with 3.2 cu
I have a coin operated washer and dryer and want to change the $ amount. How do I do it? They are Washer Model # CE2950xyL10 and Dryer is CA2762XYW0
I have a washer and dryer coin operated Whirlpool washer model CE2950XYL10 Dryer CA2762XYW0
  • 113 Answers
SOURCE: Whirlpool stackable washer/dryer. Dryer squealing
Could be the idler pulley, or the dryer seals.
Posted on Dec 16, 2008
SOURCE: whirlpool duet washer/dryer - CODE F 02 ON WASHER
I had this problem and cleaned out every hose, filter, etc. What I found was the pressure switch hose at the back bottom of the tub was stopped up.
Posted on Jan 22, 2010
  • 2468 Answers
SOURCE: whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
Posted on May 10, 2010
  • 2501 Answers
SOURCE: whirlpool intergrated washer dryer model
I have had a similar message form my machine and the only user action possible was to clean the pump.
It may be the same with your machine so follow your instructions for this.
Posted on Aug 05, 2010
heatman101
  • 43501 Answers
SOURCE: I have a stackable washer/dryer
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
Why coin operated washer coin would not come back
coin mechanism is defective as people shove all kind stuff to it ,in order to save few Penney
Apr 30, 2014 | Kenmore Washing Machines
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Coin-operated dryer won't turn off at end of cycle.
A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
Apr 22, 2009 | Maytag PYE2300AY Electric Dryer
Roper coin operated washer and dryer with no keys
call A locksmith to drill out the lock then re-key the machines
Dec 19, 2008 | Roper RAK2751WWH Top Load Washer
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Jul 04, 2008 | Whirlpool CAM2752RQ Coin Operated...
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Whirlpool 27 Top-Load Coin Operated Commercial Washer with 3.2 cu Logo
Dan Webster
Dan Webster
Sal DeAngelo
