Question about Refrigerators
Why does my fride leak constantlay (into and also to the outside onto the floor) and it is a orange - rustlike color substance that stains both my fridge and the floor.
Can I do something on my own to fix the problem?
  • Refrigerators Master
  • 5,323 Answers
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Posted on Apr 17, 2015
Locate AC drain line
ac drain pipes are on the passenger side front floor area (just about where your feet go) under car when cars heater core gets a hole in it lots of times antifreeze will leak inside car on floor try to get a small sample of fluid thats leaking out with a tissue or something (white In color) see what color fluid is ,see if fluid is slippery like oil or not (rub it between fingers)
Antifreeze= orange or green in color
Transmission oil = red or brown
motor oil = brown to black
washer fluid = Blue or drk orange
ac condesate= clear water (cold)
Nov 08, 2013 | 2001 Ford Crown Victoria
How to stain a solid wood floor
They have paint on it.If have it you have to remove old paint.Some place have machine to remove old paint you can rent.Then put new stain.
Apr 10, 2013 | Sub-Zero 611 / O Bottom Freezer...
Leaking on front driver carpet but no visual sign of leaking around door or windows. Carpet is drenched and so is cushion underneath carpet.
1. Have you been using your heater and is the smell sticky sweet? If so you're heater core might be leaking.
2. Have you been using you're A/C? If so you may have a clogged or disconnected condensation drain.
Jan 17, 2011 | 2001 Lexus RX 300
The water feeds into the unit with no outside leaks but when it gets onto the unit it leaks out into the toilet and on top of it and tehn leaks onto the floor.. The water used to shut off once the unit had...
IIt sounds like you need a new fill float assembly. First replsce the shut off valve at the wall if it's broken. The fill valve is easy to vhage. Set shut off point 5/8" from top of overflow drain tube. -Good Luck, Ned-
May 21, 2010 | NRS Brondell Swash 600 Bidet Elongated...
Something leaking from the vent inside the top of the refridgerator. It is a sticky substance with an orange color. Is it freon?
No, it sounds possibly like the glue that was used to seal the back of the fridge is leaking out. Maybe a defect, if your fridge is still under warranty, I'd call the seller to ask about what can be done from there. Freon is a gas.
Feb 08, 2010 | Refrigerators
Air conditioning accumulator assembly dumped fluid, no prior service to system
It sounds like the accumulator has either corroded or a seal is leaking, air con pipes tend to corroded, due to being aluminum and force the seal from its' seat, best thing to do is check where the leak is from exactly, it sounds like there is a special dye in the system (hence the pool on the floor). The ultraviolet light (black light) along with special glasses can spot the leak easily. Please make sure that if you have a leak that the system is vacuumed down, to avoid poluting the atmosphere. Also if you remove pipes, make sure you replace them quicly as moisture from the air will quickly upset the system. What ever the way, you need to go to an aircon specialist to get it fixed and recharged ready for the summer heat!
Hope this helps
May 21, 2009 | 2002 Mercury Mountaineer
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Mar 27, 2009 | Smeg FA561X Side by Side Refrigerator
It leaks water onto the floor.
Where is the water coming from? unless you have a leaking ice maker fitting on the back or somewhere else, the most likely cause would be a stopped up defrost drain. check inside the freezer on the back wall and floor. if you see ice you will need to unstop the drain. (most newer models don't have a removable drain pan)
Nov 08, 2008 | Hotpoint HSS25GFP Side by Side...
Yellowish-Green LEAK HELP!
I am guessing that you may have mold (green) in the water coming from your Air Conditioner or from the water channels where the water flows from the car vents to the ground. Usually green is the coolant. Could also be a prankster the poured some lime flavored pop/soda under your car or one leaked in the trunk? Did someone else park there and you are seeing their leaked stuff? Without more info, this is just wild guesses. Where is the leak seen - inside the car? under the engine? floor of a garage? outside in the street? Maybe even windshield washer fluid was that color if it spoiled?
Oct 24, 2008 | 1998 Pontiac Grand Am
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
