Question about Car Audio & Video
I have a avh x2700bs and trying to figure out the backup camera, the purple backup wire on the head unit gets the power from the backup light?
SOURCE: ipod will not play video to my head unit AVH P5900DVD
ok for the first post with the ipod not showing video .. make sure that you have the correct cable running from behind the deck to the ipod .. (iPod Direct Control (CD-I200 Required) once you have that connected you need to go to the video settings of your ipod and turn on the video out .. by default its offf... also remember with movies on your ipod .. that has to be manually selected from the ipod itself .. you cant control the videos from the pioneer unit.. only the audio/music on your ipod can be selected from the pioneer unit..
Posted on Aug 06, 2008
SOURCE: My Head Unit wont turn OFF??? Pioneer AVH-P3100DVD
sounds like when you wired the harness up you messed up some where, make sure all the wire colors match up.. yellow to yellow red to red.
Posted on Dec 28, 2009
kenw392
  • 2226 Answers
SOURCE: i have an avh-p7500/dvd and
sorry, but it will not work with out the hideaway unit. the on/off switch itself is in the hideaway unit.
Posted on Mar 11, 2011
SOURCE: HI, I HAVE A DNX6160 AND HOOKED UP THE BACKUP WIRE
hi judging by your wirering it seems to be ok did you check to see iff there was power going to the camera or the camera could be faulty also check all power leads with metre if you have one if not get a 12volt bulb and connect you reverse wirering to it or check for breakage in wire going to camera its most likely a power fault ,or camera faulty goodluck
Posted on Mar 18, 2011
ecunningham1
  • 126 Answers
SOURCE: Do I tie the purple and backup hot and hot reverse wires all together on the avh x2700bs to get backup camera to work instant on when put into reverse? Sorry just trying to clarify before I open dash
Rev. Lights go hot (powered on) the camera needs power only when rev. Lights go on, hook the ground wire for the system to a good piece of steel instead of the light system in case a failure occurs its quarantined to one area.
Posted on Apr 07, 2015
When I power up the unit, the camera is displayed immediately, the backup wire turns the screen off.
There's a wire in the head unit harness that's meant to be connected to the vehicle's reverse light wire. If you don't have a rear view camera, this wire should not be connected to anything.
Aug 06, 2015 | Pyle PLCD23A CD Player
I have a pioneer in-dash avh-p5100dvd and it has so many wires and I dont have the wire diagram how can I figure out what wires go to what so I can hook it up properly
http://www.manualslib.com/manual/310784/Pioneer-Avh-P5100dvd.html?page=6#manual
Get the plug to wire unit to and then plug it into the car; Don't cut and splice the wires. It looks bad and you can cause allot of problems. Also if you sell the car and want to keep the unit just unplug it and reinstall the factory unit.
Aug 02, 2015 | Pioneer Car Audio & Video
Apr 07, 2015 | Cars & Trucks
No sound from ipod, usb or aux?
I removed my Pioneeer AVH-P4000DVD from my Tacoma pickup to upgrade to an AVH-X2500BT and installed the AVH-P4000DVD in my mustang cobra and found myself suffering from a strange issue (that seems to have happened to a lot of you too). All of a sudden I had lost my audio on my USB and AUX inputs. I tore the net apart for a solution, pouted, drank, and started doing more and more research, and check instruction manuals. I eventually found the solution based of one lone comment someone had mentioned regarding ground and comparing the wiring diagrams for the two decks. I pulled the pioneer harness out of truck and compared it to the pioneer harness in my car and found an inconsistency. This may solve the issue that plagues you as well. Check the harness you are using. I was not able to find a pinout, but the 4 wires on one end of the harness for the AVH-P4000DVD should be +12V battery, +12V ignition, ground, and ground, (yellow, red, black, and black). If you have received the harness for a newer model of pioneer AVH it will still fit fine but one wire is out of place. The second ground wire you need has been replaced by a purple reverse gear sensor for the backup camera. Ground out the purple wire and it should solve your issue... It did for me. Good luck.
Sep 20, 2011 | Pioneer AVH-P4000DVD Monitor
Hi there...i'm having a little problem installing my pioneer avh-p6600dvd unit...couple questions. I can't seem to identify the accessory line for the unit what color is it? Do i still need the brain even...
on the back end of the deck there are a series of wire thats attached to a push-in plug.you will find:
plain yellow-wich goes to permanent live(12-14v)
red -wich allso goes to permanent live(12-14v)
black-wich goes to ground/earth
light green-wich goes to ground/earth
blue and white-wich goes to the ignition wire of your vehicle(remote)
2 x green(rear speakers)
2 x purple(rear speakers)
2 x white(front speakers)
2 x grey(front speakers)
Mar 06, 2011 | Pioneer AVH-P6600DVD Car DVD Player
I have this backup cam on the top of my license plate, got power, however, all I get is snow on the monitor ? Any ideas are greatly appreciated to get this ****** functional. Thank u for ur time and...
Look for any connections and verify that they are clean and not corroded. Some head units have more than one input, as some laws dictate that the camera can ONLY be on in reverse...so one port gets a signal from the backup light circuit, and the others do not..anyways, look for what port the wires are hooked into.
Nov 12, 2010 | Virtual Reality Black Vr3 Wrless Backup...
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Can't get unit to come on !(pioneer avh-p5000dvd)
no you should have power to audio just not video with out parking break set. check for power to head unit.check head unit fuse.
Feb 18, 2009 | Pioneer AVH-P5000D Car DVD Player
Pioneer avh 5700
i would suggest re doing all the wiring. you may have blown an ic chip inside the unit. if so you will need to get unit repaired
Sep 05, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Car Audio & Video Logo
154 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
