Question about Inter-Tel Axxess Phone 5504400
Changing the password on the administrators messaging system
Kocaso nb726a
Resetting a password without an additional account Use these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset.
"Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  6. Enter a new password.
  7. Click Save.
  8. Click the red button in the upper left corner to quit the application.
  9. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  10. Click Restart.
After following these steps, you need to update your keychain so that it recognizes the new password.
If your computer doesn't have an optical drive, connect it to a computer that does using Target Disk Mode, or use the Remote Install Mac OS X utility to start up the computer remotely. Resetting a user's password in Mac OS X v10.5 or earlier If you are using an earlier version of OS X, select your version number below for password reset instructions. Avoid setting a blank password for a user account when using these steps. Mac OS X v10.3 through 10.5.8
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" above.
  2. From the Apple menu choose System Preferences.
  3. From the View menu choose Accounts.
  4. Click the lock button if it appears locked; enter the administrator password.
  5. Select the name of the user whose password you want to change.
  6. Click the Reset Password button or the Change Password button.
  7. Enter a new password in both the New Password and Verify fields, and add a Password Hint if desired.
  8. Click the Reset Password button or the Change Password button.
  9. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Mac OS X v10.2 through v10.2.8 Use Accounts preferences to reset an account password.
  4. Click the lock button if it appears locked.
  5. Select the username whose password you want to change.
  6. Click Edit User.
  7. Navigate to the New Password field.
  8. Enter a new password in both the Password and Verify fields.
  9. Click OK.
  10. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Regardless of how many characters are actually in a Mac OS X v10.2 password, seven bullet characters (•••••••) will appear in the New Password and Verify fields the next time the password is edited. Mac OS X v10.1.5 or earlier Use the Users preference pane to reset a the password.
  3. From the View menu choose Users.
  5. Select the username whose password you wish to change.
  6. Click Edit User.
  7. Enter a new password in both the Password and Verify fields.
  8. Click Save.
Important: Passwords for administrator accounts should not be blank.
Regardless of how many characters are actually in the password, thirteen bullet characters (•••••••••••••) will appear in the Password and Verify fields the next time the password is edited.
Jan 01, 2014 | Computers & Internet
Tip
How to Break Windows Administrator Password from DOS Command Prompt?
<p>A windows administrator account is a user account that gives full access to the machine. It is by far the number one target for someone trying to gain illegal access to your network and resource. So Administrators should change administrator password frequently to avoid unauthorized access to the domain or desktop machine. <br /> <p><br /> Then something bad happens. Password can be easily forgot or lost. If you <b>forgot windows administrator password</b>, how could you <b><a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">break windows administrator password</a></b> and gain access to your admin account?<br /> <br /> <p><br /> Here is how to break windows administrator password from DOS command prompt</b><br /><br /> <ol> <li>Login as administrator or user account that has administrator privileges.</li> <li>Click <b>Start</b> -&gt; <b>Run</b> </li><img src="click-run.jpg" /> <li>Type <b>CMD</b></li><img src="type-cmd.jpg" /> <li>Then the DOS shell screen will appear like below, Type "net user username password/domain" into the command prompt.</li> <p>Replace username with the user account you login and the password with the new password you want to assign to that account. /domain is optional. If you are in a domain, specify the domain otherwise leave it.<br /> <li>Once you click<b> Enter</b>, your password will be changed, like the example, the administrator will change the password of the user Michelle to 123456.</li><img src="net-user-password.jpg" /></ol> <p><b>NOTE: </b>If you do not have administrator rights on the machine, you will get the error message stating "System error 5 has occurred. Access is denied." <br /> <p><br /> If you receive this error message that means you couldn't <b><a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">break windows administrator password</a></b> from DOS command prompt. At this time, SmartKey Windows Password Recovery comes in hands.<br /> <p> <br /> <b>SmartKey Windows Password Recovery</b> is a powerful password hacking which can help to break Windows administrator and domain password by burning a bootable <b>Windows Password Reset CD</b>/DVD or USB flash drive. With this bootable password reset cd, breaking windows admin password is a child's job.<br /> <p><br /> Here is how to <b>break windows administrator password </b>with Windows Password Recovery </b><br /> <p> <br /> Step 1: Download and install SmartKey Windows Password Recovery software.<br /> Step 2: Burn Windows Password Recovery software to CD/DVD or USB flash drive.<br /> Step 3: Breaking the lost or forgotten windows administrator password.<br /> Only need 3 simple steps. Your windows administrator password has been broken.<br /> <br /> <p><br /> <b>Contact:</b><br /> Official Website: <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">http://recoverlostpassword.com/products/windowspasswordrecoery.html</a><br /> Email: <a href="mailto:support@recoverlostpassword.com">support@recoverlostpassword.com</a> <br /> <p> <br /> <p><b>Related Article:</b><br /> <a href="http://recoverlostpassword.com/article/break-word-password.html"><img src="jiantou.gif" /> How to Break Word password</a>?<br /> <p style="font-weight: bold;"><br /> <p style="font-weight: bold;">Article Source:<br /><a href="http://recoverlostpassword.com/article/break-windows-administrator-password-from-dos.html">http://recoverlostpassword.com/article/break-windows-administrator-password-from-dos.html</a><br />
on May 24, 2011 | Computers & Internet
How do i remove system lock pin on macbook pro
Note: These steps are for Mac OS X v10.3 or later. For information about resetting a password in Mac OS X v10.2.8 or earlier, see the Additional Information section below.
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" below.
  6. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
  7. Enter a new password in both the Password and Verify fields, and add a hint if desired.
  8. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
Mar 17, 2012 | Apple Computers & Internet
I cant log on because i forgot my password
If you have any other user account with admin rights then only you can change the password..else you have to reinstall the operating system.
If you have a different account with admin accounts.
go to start then in run type in cmd\
you will see a black window.
Then follow the below steps:
To change a user's password at the command prompt, log on as an administrator and type:
net user user_name * /domain When you are prompted to type a password for the user, type the new password, not the existing password. After you type the new password, the system prompts you to retype the password to confirm. The password is now changed.
Alternatively, you can type the following command:
net user user_name new_password
When you do so, the password changes without prompting you again. This command also enables you to change passwords in a batch file.
Non-administrators receive a "System error 5 has occurred. Access is denied" error message when they attempt to change the password.
Aug 18, 2011 | Compaq Presario 1800 Notebook
HOW I CAN BREAK MY PASSWARD WITH APPLE MACBOOK AIR
Learn how to change or reset an account password in Mac OS X, including the original administrator account password. You might need to do this, for example, when someone has lost or forgotten his or her account password.
Tip: If you forget your login password and your home folder is protected by FileVault, seeI forgot the password to my encrypted home folderhttp://docs.info.apple.com/article.html?path=Mac/10.4/en/mh1909.html
Resetting a user's password in Mac OS X v10.3 or later
Note: For information about resetting a password in Mac OS X v10.2.8 or earlier, see the Additional Information section below.
Feb 24, 2010 | Microsoft Windows Vista Home Premium with...
I just set up the password on my macbook to get rid of a network settings problem and now the computer is saying i am putting in the wrong password!!!! I powered off the computer and restarted thinking...
Ok well try this... Resetting a user's password in Mac OS X v10.3 or later
    1. Enter a new password.
    2. Click Save.
    3. Click the red button in the upper left corner to quit the application.
    4. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
    5. Click Restart.
    After following these steps, you'll want to also follow the steps in this article.
Feb 06, 2010 | Apple MacBook PC Notebook
Administrative Mailbox Password-AT&T Merlin Phone System
Which voicemail do you have?
Partner Mail
Partner voice messaging.
Partner mail VS
Partner messaging.
Oct 09, 2009 | Avaya 700340193 Corded Phone
I need to change the access code as some non authorized people are using my photocopier. How can I do that?
I am answering this twice since it appeared twice, If this isnt the code you want to change let me know. I believe this is the one you are asking.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [System Administrator Settings]. The System Administrator Settings screen will be displayed.
  7. Select [System Administrator Login ID]. The System Administrator Login ID screen will be displayed.
  8. Select [On].
  9. Enter a new System Administrator userID in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  10. Select [Next] and re-enter the System Administrator userID in the field provided.
  11. Select [Save] to save the changes.
  12. Select [System Administrator Password]. The System Administrator Password screen will be displayed.
  13. Enter a new System Administrator password in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  14. Select [Next] and re-enter the System Administrator password in the field provided.
  15. Select [Save] to save the password.
  16. Select [Close] three times.
  17. Select [Exit].
    NOTE: Make note of the new System Administrator userID and password. If the new System Administrator userID and password are forgotten, a service call must be placed
Jan 29, 2009 | Xerox CopyCentre C123 Copier
I have a T5082 Gateway E-Machine and I cannot logon because I get a message that I have a password lockout. How do I solve that problem?
Reboot the system and start tapping the F8 key when the system initializes
until you see a menu appear. Select the Safe Mode option using the arrow
keys and press ENTER. Log on with the System Administrator account. (This
account should not require a password) Make the necessary changes there.
The System Administrator account is "Administrator" with a black password if you dont know. :) Hope that helps.
Jan 01, 2009 | Computers & Internet
Aip ssm password recovery
The following password recovery options exist:
If another Administrator account exists, the other Administrator can change the password.
If a Service account exists, you can log in to the service account and switch to user root using the command su - root.
Use the password command to change the CLI Administrator account's password.
For example, if the Administrator username is "adminu," the command is password adminu. You are prompted to enter the new password twice.
You can also reimage the sensor using either the recovery partition or a system image file. This will default the device.
Mar 13, 2008 | Computers & Internet
Inter-Tel Axxess Phone 5504400 Logo
48 people viewed this question
Top Inter-Tel Lands Phones Experts
george  peters
george peters
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
