Question about Garden
Please send me a diagram to run gas lines on model 775 ryobiweed eater thanks
  • 1,169 Answers
Here is a basic fuel line plumbing diagram. Note: the carburetor model may not be the one you have but it should you a good idea of you need to do.
Please send me a diagram to run gas lines on model - 25633833-vqyl0wumkkqskh4plnma1yru-4-0.png
Posted on Apr 07, 2015
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
jblee1975
  • 15 Answers
SOURCE: new fuel lines, wont stay run, swapt in/out line, wont stay run
Sometimes simply removing the carb and placing it in a carb dip will clean it without tearing it apart, also check or replace the spark plug. Make sure you have compression, good spark, and that fuel is getting to the carb. If that doesnt work, email me and I'll find you a diagram. Jblee1975@yahoo.com
Posted on Jul 12, 2009
Dolfoff
  • 148 Answers
SOURCE: can't find gas line diagram for craftsman
The drawings arent spectacular, but it's the best we have.
Click HERE.
Hope this helps.
Posted on Oct 04, 2009
Dolfoff
  • 148 Answers
SOURCE: need dighram on how to run the gas line on a
Find your exact model number and try the diagrams located HERE.
Hope this helps,
Dolf-
Posted on Oct 18, 2009
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
May 17, 2010 | Troy Garden
Fuel line diagram model 2450
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly (a "2450 Gas Saw Type 7" example IPL follows. may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2450-Gas-Saw-Type-7/75.2450-Gas-Saw-Type-7.1.59.1.html
Poulan.com (All models)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The Poulan print is deceptive, my schematic (below) is correct.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Garden
Need dighram on how to run the gas line on a mcculloch weed eater
Hope this helps,
Dolf-
Oct 18, 2009 | Garden
Gas line
What little fuel system detail ther is can be found here:
Poulan.com
Find a model number that matches your saw.
Fuel lines run from the tank to the carburetor to the purge pump and back to the tank. Take extensive notes and a few digital photos as you go are a good idea.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
HTH
Lou
Oct 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel hoses routed wrong on weed eater fuel tank
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
Gas lines on Poulan Pro model 112
i need a diagram or manual for a sears craftsman weed eater so i can put new
gas lines on it
Sep 06, 2008 | Craftsman 25cc Gas Line Trimmer
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
