Question about Dryers
Need wiring diagram showing 4 temp switches - Dryers
3 Suggested Answers
VulcanBrat
  • 23 Answers
SOURCE: Headlights don't work. Need wiring diagram for
Easy as pie..
Go to Autozone.com. Register yourself... it's FREE
Type in your vehicle info... year, make, model, eng..
Go to repair guides section. It's all there. PLUS you'll get the costs while you're on the site!
FYI: if you're not registered, you can't view guides and manuals.
Posted on Feb 03, 2010
emissionwiz
  • 76164 Answers
SOURCE: need wiring diagram for outside air temp sensor 2004 cadillac cts
The wires have no polarity, so no mater how you connect it should work.
Posted on Jun 13, 2012
Need wiring diagram
Wiring diagram for a 3-way switch, one of the many wiring diagrams showing different methods of wiring a three way switch circuit. This electrical wiring diagram shows power into light switch Box #1 – wire to light from switch box #1, and from switch box #1 to three-way light switch box #2.
Jan 06, 2016 | Holmes Products Heating & Cooling
How do I connect my Jandy AE-TI heat pump to my intermatic T104P3
1) Copy following link for wiring illustration ... assuming timer is supposed to control pool pump:
http://waterheatertimer.org/images/T104-to-contactor.jpg
2) T104P is 240Volt (208-277V) SPDT timer in P plastic outdoor enclosure.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Jandy AE-TI is 208/230V pool heater.
http://www.bestbuypoolsupply.com/media/aemanual.pdf
4) Page 13 of Jandy manual shows single-phase residential wiring diagram.
5) First of all, power to main contactor is not interruped by timer, since this powers 24Volt transformer that controls the chip board and general operation.
6) The timer is connected to 'Auto-heat contactor.'
The confusion is what Load connects to this contactor? The water pump? Load is shown on diagram as 'pump time clock.'
I assume the load is the PUMP??
Dec 04, 2012 | Hardware & Accessories
Need wiring diagram for outside air temp sensor 2004 cadillac cts
Jun 13, 2012 | Cars & Trucks
The engine cooling fans do not come on when they should. This includes the AC fan as well as the engine cooling fan.
I'm sorry but I don't have a wiring diagram for that model. However, the corolla diagram may be similar. It shows that both the ac fan relay and the engine radiator fan relay are controlled by grounding through the "water temp switch". In other words, neither fan will work until the engine is warm and the water temp switch is closed. Check out the water temp switch to see if it is stuck open (or stuck in the cold mode.)
Jan 17, 2011 | Toyota Camry Cars & Trucks
Need diagram showing a/c power and switched termanels
You posted under EH40 Intermatic timer.
The EH40 has a 240V clock
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
The terminals are numbered 1 2 3 4 5 6
The 240Volt clock is terminal 1 and 2
The first HOT wire from breaker connects to terminal 1 and 3
The second Hot wire from breaker connects to terminals 2 and 5
The wires to Load connect to terminals 4 and 6
If you need more help, add a comment and I will help
Nov 01, 2010 | Intermatic EH40 Energy Controls -...
4-Way Switch wiring
Here is a website that has great wiring diagrams for you and also a video about wiring these switches.
Your problem is that you have a "hot" going to a "common at one of the switches when you flip a swtich. This trips the breaker.
It can take alot of time and be very frustrating to find the culprit wire if you are inexperienced with three and four way circuits...it even takes a pro quite a while to figure these out someitmes. And Ohm meter is a must and you need to pull all the switches out with the power off and start tracing out each wire till you find the bad one.
You need to make sure that your switches are wired EXACTLY as the diagram shows.
http://www.askthebuilder.com/B141_3_Way_Switch_Wiring_Diagram_and_4_Way_Switch_Wiring_Diagram.shtml
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 28, 2009 | Leviton Decora Gray Rocker 4-Way AC Quiet...
Overhead console wiring diagram
Compass/Temp w/o Trip function
Yellow - Key on 12v
Black - Ground
Light Green/ Black tracer Ambient air temp sensor At about 70 deg I have almost 10K ohms resistance. Just for a point of reference.
Dark Green VSS
Brown Goes to the dimmer switch that adjusts the brightness.
Gray Goes to headlight switch so the display will dim when the lights are on
Mar 10, 2009 | 1998 GMC Blazer
Open Questions:
Dryers Logo
44 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
