Question about Maytag Washing Machines
Need wiring diagram showing 4 temp switches for maytag mav7200aww
  • 948 Answers
Richard: This website has wiring information, just scroll to the bottom right: http://www.partselect.com/Models/MAV7200AWW/
Posted on May 13, 2015
2 Suggested Answers
  • 53 Answers
SOURCE: maytag atlantis mav7200aww lid switch broke how do
Should be three screws on top of console. Remove and the console should roll forward to expose the switch. If that doesn't get you to it, take a putty knife and put it under the top on the right and left side in front of the machine and release the clips by pushing in. Lift the top
Posted on Sep 11, 2009
Maytag top load washer MAV7200AWW does not drain water sometimes
this is a very good washer, if you are not getting the water out first check the belt , second check the pump the pulley on the pump should turn freely and no play in it back and forth if you notice play in the pump replace it, next how is the washer drain hose , is it in a standpipe or connected with no air gap, if you do not have an air gap you may not be able to pump the water out plus getting sewer water back in (smells) there are products out there to clean the inside of the tub (tide makes one also afresh)
Jul 04, 2017 | Maytag Washing Machines
MAYTAG MDG7500AWW WITH BAD CONTROLLER. I HAVE A NEW CONTROL AP4043119 BUT NEED DIAGRAM TO SHOW THE INSTALATION OF WIRES.
Transfer the Wires from the Old Switch One at a time, to the Same Terminals on the New Switch.
Oct 14, 2011 | Dryers
I need to know the proper connection for the PS2035633 mositure sensor on a Maytag MDG3000 dryer
Hello, One wire is to ground and the blue wire to the temp control here is a diagram http://lookup.bellparts.com/diagramenlarge/2/0/569583/93268
Please rateme Thanks..
Jun 19, 2011 | Maytag Dryers
One burner (left front) heats up too much. You cannot regulate the temp. Everything heated on this one element burns.
This is usually caused by the infinte switch. You will need to disassemble to acess the switch. The switch is easy to test and replace. Here is a link showing how to test an infinte switch http://appliancehelponline.com/infiniteswitchvideo.html
You can also enter in your model # for diagrams and illustrations of your specific model.
Aug 25, 2010 | Maytag MEC5430BDS Electric Cooktop
Model MES5770AAB Serial 11517659WK The single element, 700 watts came with a wiring kit for a new connections. My range has "Old connection type 1" . the moddification kit (A-30001, Revision 4) shows...
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Jan 21, 2010 | Maytag Kitchen Ranges
Maytag atlantis mav7200aww lid switch broke how do you repair?
Sep 11, 2009 | Washing Machines
I have a Maytag top load washer model # Mav7200AWW. There is no power at all. I have tested the eletrical cord from the wall to the washer and there is power there. So it is not the cord. Still no power....
Below are some diagnostic hekp tips, courtesy of www.repairclinic.com.
I have included a link to the lid switch diagram, which is the most common failure part.
Also, it appears that there is no independent fuse in this model.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-Mav7200AWW-%3d%3di916383&PartID=916383
Aug 16, 2009 | Washing Machines
Maytag PYE3300AYW Elec Dryer Runs, But No Heat
hello kellygubser,
If you are sure the thermal switch is ok.. have you checked the high temp ( bi metal snap switch) too? Here is a link to the wiring diagram of your dryer. You can see that there are a few other temp switches in circuit of the heating element that would disble it.. Hope this helps
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Maytag model MDE9206AYW will not heat. Checked coil, fuses and limits and am now trying to check cycling thermister. Can you tell me how? also do you have any suggestions. suspect dryer went out during...
My generic wiring diagram doesn't show this dryer uses a thermistor, only thermostats. The difference is a thermistor has to have an electronic control to interpret the values the thermistor is sending. A thermostat is mechanical and only open or closes at a preengineered temperature. You would need to check the ohm readings of a thermistor at different temperatures to test it, but you only need to know continuity or no continuity to test a thermostat. First make sure you have 240 volts to the dryer, the heater is the only part that needs 240 to run. It's possible for only half of the breaker to trip and give the dryer only 120 volts, in this case everything but the heater would run. If you've got 240 volts, to the dryer, unplug it, then check for continuity between the 2 terminals of the 2 thermal fuses, cycling thermostat, and hi limit thermostat and heater. Remember you must disconnect one wire before testing to prevent incorrect readings. If it still runs, just no heat, the 2 thermal fuses should be ok, but check them anyways. If they all test ok you'll need to check the temp selector switch. You'll need the wiring diagram to show which terminals to check at each heat setting. If that checks out you'll need to move to the timer, again you'll need the diagram. If the timer checks, the only thing left is the centifugal switch in the motor, and the only way to check that is to test it with the motor running.
Jul 18, 2008 | Maytag Dryers
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
