Question about Kenmore Washing Machines
I Have a kenmore washer 700 series, it makes it through the prewash/soak cycle and then I get error code LF. I have it hooked up to my kitchen sink. Please help
  • Kenmore Master
  • 5,323 Answers
Might not have enough pressure power in ur water sink hoses to run the inlet valve as it take a certain pressure build up also check ur water pressure switch
I Have a kenmore washer 700 series, it makes it th - kenmore-washer-700-series-makes-prewash-qwraf2tofhw5f1pyjgshzkpc-3-0.jpg
kenmore-washer-700-series-makes-prewash-qwraf2tofhw5f1pyjgshzkpc-3-5.jI Have a kenmore washer 700 series, it makes it th - kenmore-washer-700-series-makes-prewash-qwraf2tofhw5f1pyjgshzkpc-3-9.jpg/images/kenmore-washer-700-series-makes-prewash-qwraf2tofhw5f1pyjgshzkpc-3-9.jpg
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
By the way my advice is free cuz God is good!
Posted on May 14, 2015
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Calypso
"LF" is a "LONG FILL" error. This will occur if water fill time exceeds 10 minutes. I don't know why this would pop up at the end of a cycle. Normally this is associated with filling at the beginning of a cycle. There is also an "FL" error, which is an "OVERFILL" error. This is normally associated with a problem with either the control board or wiring harness. This normally occurs when there is an open circuit between pins 1 and 3 on P17 of the control board. That one is a little more involved and usually requires replacement of the control board, wiring harness, or both. If you, indeed, have an "LF" error I would check your water source coming in. Check your fill hoses for kinks or obstructions, first. Then, turn the water supply off and remove the hoses from the back of the machine. Place one end of each hose inside the wash tub and turn both water supply lines back on to make sure you have good water flow coming through the hoses. Replace the hoses if they show signs of bulging, cracks, leaking and/or restricted water flow. Turn water back off and check the fill valve inlet ports on the back of the washer for accumulations of sediments in the screens. It doesn't take much to restrict water flow. You can clean the screens with a cotton swab. If you check everything and still have problems with the error code popping up, I would replace the fill valve. It's an easier fix and less expensive than a control board. If you decide to replace the valve, it is located under the console on your washer, I believe. It's fairly simple with a couple of screws to remove on the console and a couple of connectors and hoses on the valve to remove. Make sure you unplug the machine and turn off the water supply before attempting. I hope you find this advice helpful. Let me know if this works for you.
Posted on Jul 14, 2007
SOURCE: Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Posted on Dec 28, 2007
IFIXALL
  • 868 Answers
SOURCE: LF Code
Why not just clean the screens to increase the fill pressure and spend not 1 cent on the repair.
Posted on May 26, 2008
IFIXALL
  • 868 Answers
SOURCE: LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
IFIXALL
  • 868 Answers
SOURCE: Kenmore Oasis HE 2708..LF error code
Replace the water valve
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
My Kenmore top loading series 700 type 580 is given me a LF code can u help
LF is the error code for Long Fill.
Sometimes a bad or plugged water inlet valve YOU MAY need to replace the water valve.
In SOME cases the drain hose wash may be siphoning the water out of the washer as it tried to fill.
pulled the drain hose up out of the stand pipe a little to keep it from siphoning
Read more: http://appliancejunk.com/forums/index.php?topic=10002.0#ixzz3bkyrg7TS http://appliancejunk.com/forums/index.php?topic=10002.0#ixzz3bkyrg7TS
May 18, 2015 | Kenmore Washing Machines
Kenmore machine won't do more than fill on SOAK setting;won't run
I'm unsure how the normal operation was restored. I attempted to correct it by setting the machine to SOAK+PREWASH overnight to assure that the SOAK timer had run out. Then My wife (who never uses SOAK or PREWASH options) made a clockwise trip around the TIMER control stopping at each of the "detents" (I did not witness this) one of the spin entry points worked to empty the washwater and the NORMAL wash cycle resumed normal function.
I'm not confident that my description above contains all the essential information needed to correct this problem and am disappointed that
I cannot find SUPPORTING LITERATURE that shows how to use these alternate cycles and combinations without another hang-up like these two that I have experienced. That which is supplied with the washer is pathetically inadequate and the Sears site has little else to offer. Document #8566913 was not delivered with the machine but I did find it somewhare on the INTERNET printed parts of it for additional help. *ALERT* #1: Just now I discovered that it does cover the Model series 110.2692* of which my machine is part ... and it ALONE warns of the 20 minute mandatory wait when two controls are set to obtain SOAK+PREWASH function.
*ALERT* #2: Last nite I discovered that the lid switch makes NO SOUND when the lid is lowered normally but can be made to click by pressing on the left rear of the lid. Feeling under the lid, I found no switchpad (?) on the operating arm as shown in diagrams found elsewhere.
FINAL QUESTIONS: 1) could failure to FULLY operate the lid switch allow partial function of this machine, e.g. to fill, agitate, rinse and spin normally but not to soak or prewash? 2) can anyone direct me to a place where I can obtain breakdown diagrams repair directions for this machine?
Dec 28, 2009 | Kenmore Washing Machines
LF error
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore is rading lf at 17 minutes.
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Washer Oasis displays letters LF and is unable to complete washing cycle. Also, could you please send a manual via e-mail?
You can find owner's manual for Kenmore Oasis washer at http://www.managemyhome.com by searching for your model number. From the Kenmore owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
"Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it."
Apr 30, 2009 | Washing Machines
Stops before spin with error code of LF
Apr 20, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite model #110 27082601
In reference to the LF error code on your Kenmore Washer
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
* Error Codes- LF for long fill or FH for no water detected.
Apr 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Dec 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
203 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
