Question about Exercise & Fitness
Active minutes not syncing - Exercise & Fitness
How do i connect my fitbit device to my verizon tablet.
Syncing Your Data
  • The Tracker will upload your data every 15 minutes provided you are within range of any plugged in base station (about 15 feet for direct line of sight), the computer is on and not in sleep or hibernate mode, the software is installed and running, and you have an active internet connection.
  • While out of range, the Tracker will look for a base station every minute until it syncs your data, after which it will wait 15 minutes before searching again.
  • You can see when the last successful sync occurred by viewing your main page at www.fitbit.com. Near your profile picture, you will see Synced with a time and date of your last sync.
  • If you want to force the Tracker to upload its data, place the Tracker on the base station.
  • While we recommend you sync your data regularly, the Tracker has the ability to store 7 days' worth of detailed, minute by minute data. It will store summary data (calories, distance, and steps) for the trailing 30 days. If you wait longer than 7 days before syncing, you will not see your minute by minute graphs (except on the most recent 7 days).
  • Your Tracker is able to sync from multiple computers, as long as each computer has the Fitbit software installed and a working base station is plugged in. You don't need to physically connect the devices. Simply down load the app and upload your info.
Sep 17, 2014 | Fitbit Ultra Tracker
I'wanna pc suite driver
For normal installation , you have to install Microsoft Active Sync 4.5 for your Imate Jam and a USB cable, You can download the Microsoft Active Sync software from the link below
Once you download the Microsoft active sync , simply run the setup and it will install it automatically, then connect your mobile phone, and it will install your phone automactically
If you require more assistance, regarding this feel free to reply to this post
Regards-BA
Jan 10, 2011 | i-mate JAM Pocket PC
How do i sync my vtech CS5111 to its base...please help...
have the main based plugged into a working ac outlet and active telephone line then place phone on base for 1 minute then remove base should sync within that time
Mar 18, 2010 | Vtech Lands Phones
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
Active sync
Hey no prob sunli. What you need to do is install the "nokia pc suite" with the cd your phone came with. The set up wizard will guide you through the process.
Once you get it installed, I think (I don't have the pc suite right now, I had it before) the sync option you'll be looking for will be somewhere under the "help" menu, which is beside the other menus such as "file".
Once you've selected the option, the install "active sync" will be displayed on your phone (you have to have it connected with the usb cord it came with).
From there you'll be able to do everything you need be done such as file transfer, manage gallery, etc.
Let me know how it goes
johnny
Sep 04, 2008 | Nokia N73 Cellular Phone
Backup battery on Dell Axim X5 varies on charge left, even after complete charge. One minute it's 100%, then 0%, then 100% again within a few minutes
Install Active Sync latest version off of the Microsoft site. Turn off automatic SYNC ..... change it to manual sync.
Then check the connections on the watch battery----- you may need to add a piece of tape to the battery lid to get a tight connection. Carefully bend out the tab that contacts the battery. Wipe the battery off with a clean rag before installing.
Sep 15, 2007 | Dell Axim X5 Pocket PC
AXIM Disconnecting
Go to Start Settings System Power Control Uncheck (On external power) or set it to what ever mins you want
Sep 14, 2005 | Dell Axim X5 Pocket PC
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
Does the ipaq 2215 work with Outlook 2002?
Active Sync will work with many version of outlook. Your PDA interfaces with Active Sync. Certain versions of Windows Mobile software and/or PDA's require higher versions of active sync to sync correctly.
Sep 12, 2005 | HP iPAQ H2215 Pocket PC
Problems with installing Active Sync on Windows xp.
Do you use companion CD for Active sync installation? Can you please tell me which driver is necessary to have? Is there any error message and what is content of this message? It can also be that Active Sync is already installed! Please check at Add and remove Software in Control panel! Otherwise go to www.microsoft.com and download a current version of active sync
Sep 11, 2005 | Toshiba e400 Pocket PC
Exercise & Fitness Logo
88 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
