Question about Riccar Sewing Machines
How to disengage the bobbin mode on a Riccar 3500 sewing machine.
  • William Gilbert Apr 08, 2015
    Hi draknanster, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Do you have a Manual?
SOURCE: riccar sewing machine 8500
I don't know if this will help or not, but here is a website where you can download a manual for any of the Riccar products: http://www.riccar.com/help/manuals/
Posted on Sep 13, 2008
SOURCE: sewing machine thread nesting
I have fixed it now the bobbin case didn't seem to stay seated during sewing or tangling i should say!. I decided to change the needle and from then on everything worked fine.
Posted on May 09, 2009
bargainbox
  • 1388 Answers
SOURCE: Riccar 9700- The top thread keeps getting tangled
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 23, 2009
  • 1788 Answers
SOURCE: Looking for Riccar sewing machine manual
you can get the manual by goggling Riccar 1570 manual for free. It will download, no problem
Posted on Jul 26, 2010
hazelgrace
  • 340 Answers
SOURCE: Not sure how to tell what model Riccar sewing
Manuals are available on the Riccar site.
Have a look at a few to see if any are similar to your machine. There are quite a few but I'm afraid but that's the only way I can think of doing it without seeing a picture of the machine.
Most machine have the model number written on them somewhere, but that doesn't sound like the case here.
Hopefully your manual will be able to tell you which settings are correct for your machine in able for it to sew properly.
Hope this helps!
Posted on Oct 18, 2010
I have a Riccar 706. I can't get the upper thread to pick up the Bobbin thread. What do I need to do?
Install a brand new needle (confirm it is installed facing the correct direction).
If it still doesn't pick up the bobbin thread, the machine is probably out of time. Search for sewing machine timing or take it for service.
Jun 01, 2017 | Riccar Sewing Machines
My machineis not pickingup thread underneath not sewing
Install a brand new needle and verify it is installed correctly.
If it is still not picking up the bobbin thread, then most likely the machine is out of time. Search for sewing machine timing or take it for service.
May 25, 2017 | Riccar Sewing Machines
Need manual instructions for Riccar 2910 need help with bobbin, threding machined and tension setting and bobbin holder.
You may be better off going to google and search "riccar 2910 manual" That way you can follow their detail dorections rather then someone elses and it confuse you. Usually the PDF versions have pictures with it :-)
Apr 07, 2016 | Riccar Sewing Machines
My bobbin will not work
is machine set to darning setting , happens to a lot of them , the button is usually right next to bobbin and its easy to hit by accident this disengages the bobbin drive link so no it wont move
most units have a visual indicator for this function (but not all), but if draw toes under needle foot retract into platen base then yep it's in darning mode , you'll need to find switch and disengage this before it allows you to continue with normal sewing
Jun 24, 2015 | Sewing Machines
I have a IZEK singer sewing machine, I wound 3 bobbins with it and when I went back to sew it would not work
Sandy, I'm not familiar with IZEK machines, but it sounds like the bobbin winder has not correctly disengaged. Put it back into bobbin winding mode and run it (no need to wind a bobbin, just check that the bobbin winder turns), then stop and disengage the bobbin winder and try sewing again. Hope this solves it for you. If it won't turn the bobbin winder either then it may have slipped or broken the drive belt and you will need to take it to your local sewing centre.
Mar 02, 2015 | Singer Izek Computerized Sewing Machine
I have a Simplicity SE3 machine and I can not fine bobbins for this machine. Where can they be purchased?
The Simplicity SE3 bobbins are used for several other machines. The metal version of the bobbin is available here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-125701-001-baby-lock-bernina-brother-riccar-simplicity-white/ . These are 10 for $6. There is a plastic version that's a bit cheaper: http://www.mysewingmachineparts.com/top-quality-plastic-sewing-machine-bobbins-136492-001-baby-lock-bernina-brother-riccar-simplicity-white/ . These two links include both other machines that use the bobbin and alternative part numbers to locate them from other vendors.
If you ask at a local sewing machine store for the Brother PE100 or BabyLock BL2100 bobbins, they should be able to help you find them.
I hope this helps.
Apr 17, 2013 | Simplicity SE3 Computerized Sewing Machine
Hook Drive Gear, Riccar #53741 how to take part off of sewing machine
Today I got such a machine (Riccar) for free from a lady I know. the only problem was that the needle walked against the bobbin (timing problem).
I screwed the sewingmachine open and after some screwing I saw that the part, Hook Drive Gear, Riccar #53741, was broken. Wat I did is I enscrewed two screws wich hold the part on the axe and with a bigger flat screwdriver I could just push the part from the axe, from the other gear. It looks more difficault then it is.
Now I have to get a new part, put it back and time the the machine so that the needle will go normal, at the right time, in the bobbin. Does anybody know the trick to do that?
regards,
Daan
Apr 23, 2012 | Riccar Sewing Machines
Sewing machine thread nesting
May 04, 2009 | Riccar R650
Riccar sewing machine 8500
Feb 26, 2008 | Sewing Machines
Sewing Machines Logo
42 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
