Question about Emerson Go Action Cam 720p HD Digital Video Camera Pro Grade 5 mp
How to reset? it is stuck in video mode, however not able to record or anything else. Just view through the screen. Toggle switch doesn't work?
I can turn my camera on, but there is no screen or sight for recording or play edit.
normally, if you can turn the camera on everything should work including the lcd. if its just an issue with the imaging sensor, you wont see anything on the viewfinder (for the viewfinder to work you need to close the lcd screen) but should at least see the indicators, same in the lcd screen and view your videos in playback mode. if its an lcd screen issue, there would be nothing coming up in any mode the camera is set to. you can try to reset cam back to default settings (press reset while cam is on, its located on the side where you have the handstrap, just below the speaker), or do power reset (remove the batt and ac adapter for at least a minute). if still the same, your unit may require service. thanks. hope this helps.
Jul 21, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
Screen and view finder not showing anything
Just covering the bases...
Make sure the lens cap is removed
Turn the ON/OFF switch to Favorite mode
Press EVF/LCD does it toggle
Look to see if the battery level ICON shows better then half
Battery combination sometimes will show a strong icon level
It may be strong in the other modes which draws less power then the picture taking mode.
My guess would be New Battery replacement.
Some tests were done that may be of value to your solution
http://reviews.cnet.com/digital-cameras/kodak-easyshare-z740/4505-6501_7-31294317.html
Jun 13, 2010 | Kodak EasyShare Z740 Digital Camera
I cannot see anything on my view when on camera mode
If you can view previously recorded tapes and see icons on the LCD, you may have an image sensor (CCD) problem. See this link regarding a Canon service notice about this issue. If you think this is your problem, contact your regional Canon service facility.
Feb 09, 2010 | Canon ZR80 Mini DV Digital Camcorder
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
Olympus sp510uz no sound on video
From SP510 camera switched off:
1. Turn dial on top plate to movie mode (selections from the menu screen apply to the mode the camera is set in);
2. Switch on SP510 power;
3. Press "MENU" button on back plate;
4. Select "Camera Menu" from screen if not already on it, using navigation buttons on back plate
5. Scroll down yellow "Camera menu" tabs to microphone picture (below "Digital Zoom"), which may be showing "off". Select OK and toggle yellow tab from "off" to "on", then press OK button.
6. Microphone tab should now show "on".
7. Return to main menu (press MENU button).
8. Return to image screen (press MENU button).
9. Test to see if video now records sound.
10. If is still doesn't record sound, try "reset" from video menu screen (this will reset the movie mode to factory settings, including microphone on).
Dec 21, 2008 | Olympus SP-510 UZ Digital Camera
Video Recorder is in DV mode
try switching the input button on top right of your remote. it has 3 stages, line 1, line 2 and dv mode.
Apr 06, 2008 | Sony RDR-GX355
Stuck in movie mode, but won't record
internal microswitch connector has been damaged.so it has been stuck at movie mode ,it can be replaced.
Mar 06, 2008 | Canon PowerShot SD600 Digital Camera
"Line In" mode (on both TV & VCR) -- (Please help) "Get (them) Back to "Normal"!"
it sounds like you need to get a universal remote that has an av setting on it usuall this is 0 or an av button this shoud toggle between these modes sorry couldnt be any more help
Oct 31, 2007 | Televison & Video
Panasonic NV-GS50
check to see if iris is opening and closing, could be seized vanes on iris motor. Good luck
Mar 09, 2006 | Panasonic NV-GS50 Mini DV Digital...
Emerson Go Action Cam 720p HD Digital Video Camera Pro Grade 5 mp Logo
347 people viewed this question
Top Emerson Video Cameras Experts
Are you an Emerson Video Camera Expert? Answer questions, earn points and help others
