What causes loud roaring sound on spin cycle of Maytag Centennial MVWC400XW0 Top load washer? And where is tub spin cycle bearing located?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Bearings prob gone
Posted on Apr 12, 2015
Wash cycle will agitate 3 spins then nothing for a few minutes then 3 more and nothing again and repeat over and over
you may want to put it through a diagnostics cycle and check for error codes... Maytag Centennial Washer Repair Guide
The tub sensor can cause the washer to act strangely like that. Also there are two mechanical styles of washer branded Maytag Centennial. The model number would help to know we are talking about the one I think we are talking about.
Hope that helps!
May 27, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Recently, my Maytag Centennial washer is incredibly loud even with very small loads. This happens during the spin cycle. It almost sounds like a truck
Need new shaft bearing. Seals kit .
I've repaired lots of these. Bearing tool is required. Part W10435302 tool W10447783
Tilt washer back look around the motor. Big piece under tub. If you see mud or rust leaking out of motor you should replace this soon.
Dec 07, 2014 | Maytag Washing Machines
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Mar 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Spin Cycle
Yes its true the main support bearing is part of the outer tub and is factory set .Dry bearing will roar until it develops a leak and eventually starts a main pulley shake that will cut through the back of the outer tubs shell.The outer tub costs about $175.00(varies)the labor (please sit down)yes, is high enough for you to go out and find your self a 15 year old Maytag top load, re-build it,scrap the front load,and never see a repairman for the next 15 Years.No joke!                             I/m happy to help you with anything you need a answer to.............Sorry about your Maytag    :(
May 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle
  Did it make this noise just when it stopped spinning.  Just for a couple seconds?  If so,  it's only brake noise and not a concern.  If it does this all during spin you probably have a bad tub bearing.  Is it a roaring noise?  This is what the bearing will sound like.
Oct 28, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
