Cars & Trucks Logo
A
Anonymous Posted on Apr 07, 2015
Code 1475 1471 1477 1472 and wont start sonetimes
  • sonofthecapt Apr 08, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    P1xxx codes are manufacturer specific, meaning P1475 could mean one thing for Ford, but something completely different for Nissan, and so on. Please include the vehicle make and model and I will gladly try to help you figure this all out :)
Rhonda Webster
Level 3:
  • Cars & Trucks Master 978 Answers
  • Posted on Apr 08, 2015
Rhonda Webster
Level 3:
Answers
978
Questions
Helped
446563
Points
2917
This should give you some problems to look up:
P1471 EVAP Emission Control LDP Circuit Short to B+
Possible failuer of OBD II Fault code P1472
  • Signal line short
  • Sensor failure
P1472 EVAP Emission Control LDP Circuit Short to Ground
P1475 EVAP Emission Control LDP Circuit Malfunction/Signal Circuit Open
P1477 EVAP Emission Control LDP Circuit Malfunction
1helpful
I have a 1997 pontiac bonneville i have a few issues. One is it just started getting soaked front and back passenger floor boards. Sonetimes will steam on window how do i check to see if its for sure
Check and see if your heater core is leaking. A leaking heater core will cause your windows to steam up and leak fluid on the floor. also cause every thing to get sticky a feeling if it continues to leak. Should repair ASAP. Needs to be replaced.
How do I change egr valve on a 2005 chrysler pacifica ?
If car does not stay runnin or stalls wen slowin down is egr effects. It may be the gasket wher it connects to engine. Sonetimes u can blow out carbon in the valve itself. Seek a shopmanual at local library
How do you replace the vent valve in a 2001 chevrolet impala
check for vacumm leak check your your fuel cap sonetimes the gasket on the gas cap gets worn out
New cpu but ignition fuse still blowing
Are there any additional peripherals installed? Sometimes the alarm guy or whoever tap into a live wire not regarding what it controls. Other times a vehicle involved in an accident pinches wires abd it doesn't show up sonetimes for months. The ignition fuse you refer to is which fuse in which fuse box. All the fuses have numbers.
3helpful
Idle problems, when stopping car stalls, sonetimes
mcdvito75 Here, Sounds like an idle speed motor or the idle speed sensor. Have your local shop check it out.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
