Question about Kenwood Car Audio & Video
Which wires go together on a kenwood kdc-210u CD receiver to a 98 Chevy cavalier
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
Posted on Dec 09, 2008
SOURCE: kenwood cd receiver KDC-MP436U
Protect:- The speaker wire has a short circuit, or touches the chassis of the vehicle, then the Protect function is activated. Wire or insulate the cable properly and then press the reset button. If the "Protect" code does not disappear, consult your nearest service centre.
Posted on Apr 18, 2009
foskorider
  • 79 Answers
SOURCE: kenwood kdc-x491 wiring diagram
red, yellow, black/ign constant ground
blue, blue white stripe/rem pwr ant
grays, whites, purples, greens/ front front rear rear
its the same on all headunits except cheap *** wal mart headunits
Posted on May 18, 2009
  • 146 Answers
SOURCE: wiring diagram for a kenwood KDC MP232
Aftermarket cd players are all universal and have the same colors. You need to go to your local car audio store such as walmart, bestbuy, ect and buy a wire harness adapter. Then all the wires are color coordinated to make it easy, just wire colored wires together and plug in. If I have helped please leave positive feedback. Thanks
Posted on Jun 08, 2009
smarthome2
  • 1114 Answers
SOURCE: I was given a Kenwood KDC-1011S. All wires labled
Yellow is for constant 12v. (Power directly from battery) so it maintains preset stations and clock memory. Red is for Key "on" 12v Power (turns on when ignition key is on) Black is for Chasis Ground. What type of vehicle is it going in? I can get you the corresponding vehicle color as well. Post a comment with make/model & year vehicle. Hope this helps.
Posted on Aug 17, 2009
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Is there a reset button on a Kenwood KDC-210U?
Yes there is a recessed reset button on the KDC-210U. It appears to be accessible only when you remove the detachable faceplate. Once you remove the faceplate, look at the lower half of the unit a bit to the left of the center of the CD-Receiver. The placement is shown on page 3 of the user manual. Kenwood has the manual on their support site. The direct link to the manual is http://manual.kenwood.com/files/GET0939-001A.pdf .
I hope this helps.
Apr 13, 2016 | Kenwood Car Audio & Video
Why is there no audio output?
Daniel, is there a separate amp that is not powered on.
Mar 04, 2016 | Kenwood Car Audio & Video
Kenwood kdc 210u stereo wired to a 1994 gmc jimmy
Whats your question?? Are you asking how or do you have in issue with it??
Aug 26, 2014 | Car Audio & Video
Wiring diagram for kenwood krm 440u
can't connect the Kdc 400U to the 98 Mustang...and got a new wire harness
Mar 03, 2013 | Kenwood eXcelon KDC-X469 CD Player
Where can i get a wire harness for my kenwood kdc 1032/ detach face installing in a 94chev cavalier
You can get this part from strereo install shops, they have tons in stock, usually.
Apr 03, 2011 | Kenwood KDC-1032 CD Player
Wiring diagram for a kenwood KDC MP232 to a 2003 chevy malibu
Jun 08, 2009 | Kenwood KDC-MP232 CD Player
In my 1995 Chevy Lumina
check if you're getting power to the red and the yellow, it may be that you are only getting a permanent live but no switched live and if so you will need join the red and yellow on the radio side together using the connectors on the loom so you will have one permanent live leading into two (red and yellow) wires into the radio. clear as mud, good luck
Dec 06, 2007 | Kenwood KDC-135 CD Player
Car Audio & Video Logo
124 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
