Question about Sunpentown SF-0703 Desktop Fan
How do I fix my desktop fan?
The fan gets very loud, It is like hearing a jet take off. The noise just gets louder and louder. I tried putting a towel under it and cleaning the blades and nothing is helping.
    Top Expert:
  • Sunpentown Master
  • 74,136 Answers
Replace it with a new one.
Posted on Apr 07, 2015
Testimonial: "Are you offering to buy it for me?"
Laptop making loud fan noise like its overheating,
Go buy a can of compressed air and blow out the fans and vents. That should get it running quiet again.
Jun 08, 2012 | Acer Aspire 5336-2524 Intel Celeron 900...
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
Computer froze & would not respond to anything. I turned off the power & then restarted. Screen was blank. Computer sounded as if it was starting but then got louder & louder, sounded like a...
lisay ,I think your smps has damgeed,if you are on line it wold be solve eassyly.Any way if want you remove the cover try another smps install temporary and try it
Nov 12, 2010 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
During spin cycle washer is making loud noise
If it is making a sound like a loud rumbling sound similar to a jet plane taking off, it probally due to the seal has failed causing water to leak into the bearings. The bearings begin to rust, and no longer round and the noise gets progressively louder. It can be rather expensive to fix. Get a few estimates before deciding whether it is worth fixing.
Aug 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Loud noise when turning on my computer
THIS IS NORMAL!!!
When the machine boots up the fans are running at full speed, and after a moment the bios loads teh power management that lowers the fans to the needed speeds. If you tax your computer the fans will speed up to compensate for the heat produced and will get louder then as well...
The larger and more powerful your CPU and Video Card the louder the startup will be. Some of the newest quad core computers with high dollar vido cards will sound like a jet taking off when starting up, I know mine does!
Aug 11, 2009 | E-Machines eMachines Desktop PC
My computer won't start up, I just have loud fan noise.
Hello!!
Might be the SMPS problem ,,, atleast can u see the blank screen or not at all powerig up ?
Jan 21, 2009 | Dell Dimension 9200 PC Desktop
Louder whirring noise when turning on computer
trumpjd,
Usually on startup the fans work a little harder then slow down. On newer computers they still have noticable fan noise. Most of what ou hear while the machine is running after start up is the power supply fan. When it starts to go bad you'll hear it all the time.
randy320sgi
Jan 09, 2009 | E-Machines eMachines Desktop PC
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
CPU Fan.
Make Sure your thermal compound is properly placed, check the temp of your CPU. CPU might be overheating due to destroyed layer of compound and therefore Fans run faster...
Sep 27, 2006 | Gateway 500GR PC Desktop
Sunpentown SF-0703 Desktop Fan Logo
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Mister Danger
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
