Question about Video Cameras
When I try to record the screen says 'check tapes erase protection tab'
What does this mean (my manual has gone AWOL so I can't look it up)
  • Video Cameras Master
  • 3,960 Answers
Normally, tape cartridges have a protection tab on them that when removed prevents users from recording over. A piece of masking tape over the empty hole will allow you to record on the cassette.
Posted on Apr 07, 2015
VCR ejects tape, and there is a key symbol on the screen. What does that mean?
Are you trying to record on the tape?
If yes you need to tape off the record block tab on the bottom that was removed to protect the content
Dec 31, 2014 | Televison & Video
How to record a cassete tape
Typically, to record on a cassette tape you must press BOTH "Record and Play" buttons at the same time and the tape recorder will begin to record.
Nov 26, 2014 | Audio Players & Recorders
I cant get this product to record a video and view whats been recorded? When i try to record it tells me to(check tape's erase protection tabe.)m
It sounds like you are talking about a VHS tape look at the lower left corner of the tape as you are putting it into the vcr there should be a small square hole there with the tab broken off put a piece of scotch tape over this hole it will than let you record on the tape again
Mar 20, 2011 | Video Game Consoles & Games
Tape doesn't stay down, keeps popping back out of cassette, on my Sony CCD-TVR608. Any ideas?
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Aug 17, 2010 | Sony Handycam CCD-TRV608 Camcorder
When i put a tape in it ejects it..then a tape with a slash appears on the screen
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Samsung VP-D102D Camcorder
Remove the DV tape from the camcorder and check the position of the red tab on top of the tape. Reverse the position and see if it protection goes away.
Jan 17, 2009 | Samsung SC-D105 Mini DV Digital Camcorder
When trying to record
You need to check the small switch on the tape and switch it the other way.
Feb 26, 2008 | JVC GR-D244 DV Digital Camcorder
Sharp Viewcam VL-AH151 Hi-8
Make sure the little red tab on top of the tape is set to record and not save. The camcorder will not let you record it its set to save
Jan 20, 2008 | Sharp Viewcam VL-AH151U Camcorder
I can't start recording.
# You may not have turned on the camcorder to record properly. For camcorders that feature both Automatic and Manual recording, make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode. # Automatic recording places the camcorder into Auto Shot™ mode, while Manual recording mode allows you to control many of the camcorder's special features, including accessing the menus and setting the clock. # For many other camcorders, make sure the CAMERA/OFF/VCR switch is set to CAMERA. Make sure the Erase Protection tab is in the position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape or use another tape.
Sep 06, 2005 | RCA CC-432 Camcorder
Record problem
Make sure the Erase Protection tab is in the closed position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape.
Video Cameras Logo
118 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
