2009 Toyota Corolla Logo
m
michael Posted on Apr 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the vss on the 2009 corolla? i know its on the transaxle but Im having a hard time locating it..
Eric Cunningham
Level 2:
  • Expert 126 Answers
  • Posted on Apr 07, 2015
Eric Cunningham
Expert
Level 2:
Answers
126
Questions
Helped
52696
Points
409
Http://www.toyotanation.com/forum/324-10th-gen-corolla-2nd-gen-matrix-suspension-brakes-wheel-forum/381204-2009-rear-speed-sensor-problem.html
Testimonial: "thanks for the response but I don't think its the wheel sensors but the vehicle speed sensor..code is po500"
2 Related Answers
Anonymous
  • 297 Answers
  • Posted on Jul 26, 2011
SOURCE: will a defective vss cause
Most definitely it will.
Anonymous
  • 672 Answers
  • Posted on Jul 28, 2011
SOURCE: will a bad vss cause
yes this will cause issues with the transmission. This also controls shift points depending on the speed of the vehicle and accelerator angle.
How to replace vehicle speed sensor 2000 Pontiac aztek
you have to raise vechicle support vechicle on jack stands. remove right front wheel. VSS sensor located upper right end of transaxle near the right inner CV joint.now your vechicle transaxle 4T65 E has a VSS and a ISS SENSOR which located inside transmission thats dealership fix. you have to remove case cover to remove the input shaft speed sensor.
1helpful
Location for toyota rav4 vehicle speed sensor
Hi there:
The VSS (Vehicle Speed Sensor) is mounted on transaxle and contains a three pin electrical connector. Remove necessary components for access to VSS. Disconnect electrical connector at VSS...
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
My 93' corolla's check engine light comes on sporadically. i used the wire method to check what the problem was and i got problem code 42. i cant find anything on this, nor does it actually explain...
There are 2 different listings for a VSS for that model Corolla - one for the 1.6 3 speed automatic, and another for 1.6 manual and all 1.8 applications. It appears to be located on the top rear side of the transaxle case.
When the light comes on, does the speedometer act strangely?
1helpful
I have a 2009 Corolla XRS with 26,000miles. The check engine light just came on, the stability control mode was turned off and can't turn it back on, and car has lost power and doesn't shift well....
probably it will be the vss ( vehicle speed sensor ) problem its located on the flywheel
thats why the computer cannot detect speed in right measures and thats why it cannot control the stability control system because it can`t read the car`s (wheels) speed in right manners so it halt the both systems ( the fuel injection calculating pattern and rotation of wheels )
its common thing easy to fix and reset the computer allowing the check light to be off
2helpful
How easy is to replace the speedometer sensor on a 1998 audi a4 cuatro auto
ALL YOU HAVE TO DO IS SAFELY RAISE SUPPORT VECHICLE ON LEVEL SOLID GROUND.THE VECHICLE SPEED SENSOR LOCATED ON THE TRANSAXLE ON THE OUT PUT SHAFT HOUSING.YOU NEED TO DISCONNECT THE ELECTRICAL CONNECTOR FROM THE VECHICLE SPEED SENSOR.THEN REMOVE THE MOUNTING BOLT WITH DRAW VSS SENSOR FROM TRANSAXLE.REPLACE THE VSS OR VECHICLE SPEED SENSOR AND O - RING.YOU ARE DONE.INSTALL THE NEW VSS SENSOR AND NEW O - RING IN TRANSAXLE. THATS ALL.
1helpful
Where is the speed sensor located? and how do i know if thats wat the problem is?
On the transmission.
Removal & Installation 3.0L (Except SHO) To Remove:
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle.
  3. Remove the catalytic converter Y-pipe.
  4. Unplug the vehicle speed sensor VSS electrical connector.
  5. Remove the VSS protective heat shield.
  6. Remove the retaining bolt from the VSS.
  7. Lift the VSS out of the transaxle.
  8. Remove the driven gear retainer and the drive gear.
To Install:
  1. Inspect the O-ring on the sensor and replace if necessary.
  2. Install the driven gear and the retainer.
  3. Place the VSS into the transaxle.
  4. Tighten the retaining bolt to 36-53 in lbs. (4-6 Nm).
  5. Install the VSS protective heat shield.
  6. Attach the VSS electrical connector.
  7. Install the catalytic converter Y-pipe.
  8. Lower the vehicle.
  9. Connect the negative battery cable.
1helpful
2answers
This is what it looks like:
VSS with connector and driven gear
Here's the steps on getting to it and replacing it:
  4. Unplug the VSS electrical connector.
To install:
  4. Tighten the retaining bolt to 36-53 inch lbs. (4-6 Nm).
6helpful
2answers
2002 Sunfire TCC Solenoid replacement
hi..the transaxle converter clutch . tcc. uses a solenoid -operated valve located in the automatic transaxle to mechanically couple the engine flywheel to the output shaft of the transmission through the torque converter.that reduces the slippage loss in the converter.reducing emissions.but check the vss first.which is called the vehicle speed sensor.they both work together .if the vss is not working right it wont call on the tcc.
check this out..
thank u..
rate me..
1helpful
1999 Saturn sl speed sensor
The vehicle speed sensor (VSS) is located in the differential area of the transaxle. Also, to replace it should be fairly simple. I wish I could give a better answer exactly where it is at, but I have you the answer straight out of the Haynes manual.
To replace the VSS, disconnect the electrical connector from the VSS. Then remove the retaining bolt and lift the VSS from the Transaxle or simply unscrew the VSS. Installation is the reverse of removal.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
