I keep getting ep show up on my ge. Why? - Computers & Internet
  • Jim R Sep 02, 2015
    Hi Jerry Davis, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? More specific information is needed. I believe this is unlikely a computer motherboard and more likely some kind of appliance in which case this question should be posted in a more appropriate category. You don't supply any GE model numbers, and as far as I know, GE doesn't make motherboards for Personal Computers, however I've seen recalls for GE refrigerator motherboards. If you are talking about a fridge motherboard, I would contact G.E. and ask if your model is covered under their recall.
Ge air conditioner error code ep
GE EP code is main compressor sensor.
Check damage to the temperature sensor
Sensor Cable left side yellow.
My airco got visited by a rat and damaged the wiring.
Cut it rejoined and code 32 changed into temperature.
You need the sensor. Just joining the cables will issue 99 and it will cut off and change into 32
You need a working sensor.
Apr 23, 2013 | Heating & Cooling
My ge AEW18DMG1 window unit shows an error code EP. What does it mean?
Jun 01, 2012 | GE Air Conditioner Main PCB - WJ26X10241
SONY keeps switching to EP at beginning of playing SP tapes
You may have dirty heads in the vcr---most 4 head machines use two for sp and the other two for lp and or ep.
Tape residue will usually be seen on the drum where the heads are when this happens--also look for the black residue on the tape guides that hold the tape in position against the drum-------
Apr 27, 2012 | Sony Televison & Video
I get an error code EP on my GE room Air conditioner. what does this mean? i did what someone suggested and unplugged it; replugged it and reset it; still did not work,.
Sep 10, 2010 | GE AJCQ08ACB Air Conditioner
I have an GE air conditioner with ''EP error code, and compressor stops.
Jul 01, 2010 | GE Heating & Cooling
I bought a tv/vcr combo from a guy no remote no manual i have a universal remote for it i am trying to run the tape in ep mode but i cant get it to change over i see the option for it in the menu i can...
sometimes a universal remote will lack certain functions like that or label them differently if possible put it on the vcr controls and try to scroll down to the ep input alot of the time it will be in between 99-01 unfortunately you may need to contact the manufacturer and see about downloading a manual for it if you would like us to please just leave the model number and make of both tv and remote and we can run a compatibility test to ensure you should be getting full function
Robb
Apr 29, 2010 | GE 13TVR62 Combo
What does EP mean on the air conditioner display?
I had this same problem with mine, i unplugged it and pushed the reset button on the side and now it's working fine.
Aug 25, 2009 | GE Heating & Cooling
EP Message - no cool air on a GE Air Conditioner
I just posted this on another one, but try unplugging it and pushing the reset buttons on the side of the plug. It worked to fix mine so far...
Jul 27, 2009 | GE Heating & Cooling
My Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Jan 14, 2009 | Minolta EP1030/1030F CS/PRO Copier
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
