My TV won't turn on. No power whatsoever.
Was working fine, then one day just shut itself off and won't turn back on. No backlight, no red light, no nothing...should I just throw it away or can it be saved? Thanks so much
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 07, 2015
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Nov 26, 2009 | Televison & Video
Power up problem
The problem is in the relay built into the power supply. It is magneticly sticking into the off position. Unplugging it kills the field and let's it set back to a neutral position. I doubt the relay is serviceable by itself.
Probably need a new power supply.
May 08, 2009 | Televison & Video
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Pioneer sd532hd5/kuxc/ca powers down on its own
Could be a few things.First check your sleep timer.Sounds like a fail safe mode that when the tvs left on accidentally it shuts itself down so it wont overheat and die prematurely.The last resort is to remove the circuit board and carefully inspect the solder joints near the power supply with a magnifying glass and a bright light.Then resolder those.
Nov 09, 2006 | Pioneer PRO-100 TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
