Touch pad don't work at all
There is no pointer touch pad there is no respond at all
    Habit-Forming:
  • 82 Answers
After windows? start press and hold the Fn button and then press one the F7 button.
if not work, try to conect an external mouse and let me know if is being working.
Posted on Apr 07, 2015
My touch pad not working probably .
Adel Heider,
You may want to first download the driver and install it into the system from the link below.
Inspiron 1545 Drivers Download Page
http://dell.to/14IpAJU
Erratic Pointer Movement
Here are some easy steps to take to determine the problem with a touch pad demonstrating erratic pointer movement:
  1. Get the latest driver from support.dell.com - Most problems can be corrected with a simple driver download. This should always be one of the first steps when diagnosing any touch pad problem.
  2. Check for hand and finger placement - The most common cause of random pointer movement is that the touch pad senses a finger or part of the hand near the surface of the device.
    • Have the customer attempt to use the touch pad normally but to pay attention to the location of his or her hands and fingers. Are any straying too close to the touch pad?
    • Adjust the Touch Sensitivity and TouchCheck settings in the Touch Pad Settings section of the Dell Touchpad Properties.
  3. Try an external mouse - Does this problem happen with an external mouse attached?
    • The Device Select section of the Dell Touchpad Properties has options to enable or disable the touch pad or external mouse. Try several combinations of these settings.
    • If the problems only occur when the touch pad is enabled and do not occur any time a mouse or other external device is used, then the issue is related to the touch pad.
  4. Check for mechanical problems - If the problem cannot be corrected by adjusting the settings mentioned above and only occurs with the touch pad enabled, then this could indicate a mechanical problem.
    • Press down on the palm rest on first the left side of the touch pad and then the right. See if the cursor starts moving on its own.
    • Run Dell 32-bit Diagnostics and try to recreate the problems there. If either of these situations occur, then replace the palm rest.
No Pointer Movement
No pointer movement from the touch pad (or track stick, if available) usually is the result of one of two things: The touch pad has been disabled in the driver interface, or the touch pad cable is damaged or disconnected. Follow the steps below to determine the problem.
  1. Connect an external mouse - In either situation, an external mouse should still function. If it does not, try booting into Safe Mode and testing both devices again.
  2. Enable the touch pad in the driver settings - Using the external mouse (or key strokes if no mouse is available), go into the Dell Touchpad Properties. Go to the Device Select section and enable the touch pad. If already enabled, get the latest driver from support.dell.com.
  3. Test the device in Dell 32-bit Diagnostics - To eliminate a potential software problem, run the Dell 32-bit Diagnostics and test the device here.
  4. Check for mechanical problems - As a last resort, press down on the palm rest where the touch pad connector is located on the system board. If the pointer reacts in some way, then the cable may just need to be reseated. Otherwise, replace the palm rest.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 07, 2013 | Dell Inspiron 1545 Notebook
How to used the touch pad
Use the touch pad to move the pointer around the screen.
Run your finger over the touch pad in the direction you want the pointer to move and then click the left touch bar (this works as the left button on a mouse).
Apr 16, 2012 | Computers & Internet
Mouse doesn't work. touchpad works fine. lenovo G470
LOL, go into the mouse and touch pad properties and make sure you don't have the mouse disabled or blocked.
Does the point work from the touchpad when you have the usb mouse plugged in? If not you have the mouse pointer disabled. There might be a button at the top of the touch pad in the middle that you press to toggle the mouse pointer. There could also be a set of keystrokes you hit to toggle the mouse. For example I just worked on one last week where you had to Press and Hold the Alt key then hit the F6 key. Function Key F6 had the icon of a finger inside a square which represented the touchpad.
Click Start/Control Panel and look at the mouse and touchpad properties. There may be settings where you can disable one if the other is present.
Apr 08, 2012 | Computers & Internet
I was just working on my laptop using my touchpad mouse. I'm sure I accidently hit a button but I didn't think I did. Well anyways, the pointer stopped responding and the orange light in the top...
many touch pads have a switch that you can toggle on and off to turn the touchpad on and off. It is usually in the immediate area of the touch pad.
May 11, 2011 | Computers & Internet
We just bought an HP G72-c55DX1 and trying to use the touch pad is driving us mad. It is very hard to control movement and sometimes just jumps. What can be done?
hi
just go to control panal then select mouse & Touch pad [name may be different because you don't intimate the operating systems] settings then
go to pointer option un-check the box showing " Automatically select default option"
and change the mouse speed using slider as you comfort
if any problem replay me
May 01, 2011 | HEWLETT-PACKARD G72-C55DX Laptop
My laptop Touch pad is not working properly
try to defragment ur laptop hard disk from windows defragmenter
this migt solve ur problem
Mar 31, 2010 | Computers & Internet
Pointer jumps around on screen when touching touch pad
hello, have you tryed adjusting the sensitivity of the touch pad to a less sensitive touch ?
Mar 31, 2009 | Acer Aspire 5610 Notebook
Lenovo Y510 keyboard not responding
first try to search a new material with configuration panel ,if you don't find anything replace it at your resseller
Dec 15, 2008 | Lenovo IdeaPad Y510 Notebook
Compaq armada 500 (touch pad not working)
look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
May 23, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
