When I turn the tv off I want the same channel when I turn it off too appear
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
The main system control memory IC to your TV is faulty. Replace it. Contact any service technician.
Posted on Apr 07, 2015
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
HOW DO YOU GET CHANNELS REPROGRAMED INTO THE TV?
Hello
Auto presetting channels you wish to know I thinks, if so do the following.
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
? When AUTO PRESET CH action is completed, the lowest memorized
channel reappears on the screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH",
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
OK.
Jan 11, 2011 | Emerson EWF2004 20" TV
Can't change TV to CATV mode
You must unplug the cable connecting the television and the cable box. Then turn the television off and then back on. Do not turn the cable box off or disconnect the cable in wire from the cable box especially if you use Cable Vision. It will take up to 20 minutes before the box comes back on. Now turn the television back on. When you access the Channel System menu, you have the access to the submenu choices. Change the Antenna option to CATV and the Current Channel to 3. Reconnect the cable box to the TV.
Also those that are having problems with the TV turning off periodically, make sure the sleep mode option does not have a number in it. For example, if the number is 10, it will turn off every 10 minutes.
Sep 05, 2009 | Memorex MT2206 TV
''big black box that appears in the middle of the screen on certain channels''
It's your "closed captioning." Just turn that feature off, and you'll be good to go!
Jun 12, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Black box when tv is on and going through channels
This worked on my tv...give it a try:
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | JVC AV-36S33 36" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Finding the correct channel on the TV for Wii
ok. push tv video button on your tv,
or
first turn on your wii, be sure that the av cable are connected to ur televison properly. Then turn on your tv start from channel 1 then scroll down the channel button until you locate the blue screen or logo of wii.
Jan 24, 2008 | Video Game Consoles & Games
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
